Sunoco 100 Octane!!!
Old Sep 3, 2007 | 10:13 AM
lsc86's Avatar
lsc86
Default RE: Sunoco 100 Octane!!!
If you're having a bit of trouble with some occassional detonation with your higher than stock compression on 93 octane, why not just take a touch of timing out of it? Double up the base gasket? Shave the piston dome a fuzz to take a smidge of compression back out of it? With good heads, you should be able to run ten and a half to one on pump gas in the flat lands. Where is your's at? Seems to be easier ways to solve that issue than over paying for race fuel you don't really need.
I like running half 100 and half 89 just for the pure smell! But since the compression on my scoot is still stock, I just run 89 in the warm weather and 87 in the winter, no problems with detonation ever.
Fuel myths are almost as prevelent as oil myths, but the bottom line is that you really want to run as low as an octane rating as possible with worrying about detonation. Now granted not all gasolines are created equal [Honda racing doesn't run $100/gallon Elf for nothing], but for the average street application, whatever you can get your hands on will be just fine.
Old Sep 3, 2007 | 10:37 AM
Chicago Spike's Avatar
Chicago Spike
Stock bikes don't need and do NOT run better with higher than 93 octane. As I said before, it is a myth that has been shot down numerous times. The only one that benefits from you using that high priced stuff is the fuel company. Cause their ad execs were successful in brainwashing another person.
Go ahead an line their pockets some more, they love you for it
Old Sep 3, 2007 | 10:47 AM
NCCopBikeRider's Avatar
NCCopBikeRider
Be cautious that you do not run leaded fuel in a bike with 02 sensors.
The lead will "Kill" an 02 sensor with just one tank.
Ride Em Carry Em
Old Sep 3, 2007 | 11:13 AM
combat_vet's Avatar
combat_vet
Take your POV up there with a couple 5-gallon gas cans and put stabilizer in there if you won't use it for awhile!
Old Sep 3, 2007 | 11:47 AM
jack49's Avatar
jack49
If you need 100 octane to make your stock motor run right, you've got a tuning
problem. I've played this game with past highcompression builds,and it's a pain in
the butt.Depending on how radical a build you're doing, you can getgood HP
and torque from a motor with less than 10 to 1, and run real well on 93 octane.
Tough to plan a road trip around Sunoco gas station locations.
Old Sep 3, 2007 | 08:50 PM
maineultraclassic's Avatar
maineultraclassic
ORIGINAL: jack49
problem.
Who has a stock motor? Not me.
Steve
fox chaser
Jan 31, 2015 03:30 PM
oldblueroadking
Feb 15, 2012 01:54 AM
paguy
Dec 2, 2011 03:29 AM
grumpy56
Jan 30, 2011 07:57 PM
the4thgearkid
Jun 28, 2010 03:49 AM
