Super Cush.
Old Oct 10, 2024 | 08:02 PM
Harley_ish's Avatar
Harley_ish
Originally Posted by Leimy
YUP, upgraded mine recently. Did a rear wheel upgrade: new rotor, new bearings, new cush drive, new brake pads. Bike has 40K miles now.
I hope that's not the way you installed it to use
Old Oct 10, 2024 | 08:57 PM
Leimy's Avatar
Leimy
no.....I was just taking a picture. Besides....it DOESN'T FIT ANY OTHER WAY...
Old Oct 11, 2024 | 09:24 AM
lp's Avatar
lp
I had one of these for a few months and found it added a ton of vibration in the lower RPMs when the bike was ridden two up and heavily loaded. Was fine otherwise.
Ended up taking it off and going back to the OEM since I tour on this bike a ton.
I will say it does everything else they say it does.
Tightened up the driveline nicely, shifts were smoother, and I'd swear throttle response felt quicker. Worth it for those seeking a sportier ride...
Old Oct 12, 2024 | 03:04 PM
cowboydoc's Avatar
cowboydoc
Interesting.
I’ve replaced mine with the OEM 3 times over 80k miles, roughly every other rear tire change. It always feels a little tighter and more responsive when it’s changed, but wasn’t sure how much was the new tire, bearings, and I’m usually also changing fluids around the same time vs the cush drive. I never knew there was an aftermarket one.
Old Oct 14, 2024 | 09:20 AM
hattitude's Avatar
hattitude
Originally Posted by cowboydoc
Interesting.
I'm curious...
Did you replace it as preventative maintenance?
Or, did you follow the directions in the service manual for testing it and it failed to meet spec, so you replaced it?
I'm at 50K miles on my bagger, and test it every time I have my rear wheel off for a new tire (or any other reason) and mine has not failed to meet spec...?
I have put the last 24K miles on my bike with a 124" S&S crate engine @ 135HP/151TQ. I certainly don't beat on my bike, but I do play a little bit here and there. My OEM rubber isolator has been holding up well...
Old Oct 15, 2024 | 12:25 PM
cowboydoc's Avatar
cowboydoc
I'm curious...
The first time, I believe it was still in spec but near the upper limit. Since then I have just replaced it every other rear tire change. Maybe my original one would still be good?
I also replace wheel bearings every other tire change. I’ve never had an issue but it makes me feel better.
Old Oct 16, 2024 | 03:35 PM
PoCoBob's Avatar
PoCoBob
I'm not sure if you're joking or not, but it should look like this when installed correctly
Old Oct 16, 2024 | 04:03 PM
Ultra103's Avatar
Ultra103
Originally Posted by internet troll
I feel old just asking. What is this thing? Sounds like its some sort of damper from belt to wheel? Whats next, air conditioning?
HD's only been using them since the early '80's. Royal Enfield invented them quite some time before that.
Old Oct 17, 2024 | 08:42 PM
OLD 96's Avatar
OLD 96
OP posting here. Just got back from a1300 mile ride. Between replacing the fuvked up TBW assembly and installing the Super Cush. Well. It was like riding a whole new motorcyle. Smoother, tighter between shifts and just all around a better ride. Thats all I have to say about that. Ride safe and be careful.
Old Oct 17, 2024 | 09:29 PM
OLD 96's Avatar
OLD 96
The image in post # 11 and post #17 are totally different setups. Maybe one for a Big Twin and the other for a Sportster.?
