Just exhaust?
Old Nov 26, 2005 | 08:07 AM
liam51's Avatar
liam51
Default RE: Just exhaust?
Thanks John,
I was told about the whitening of the plugs by my dealer. Perhaps he wanted to sell me stuff???? Anyway, the race fueler should be a help, correct? and because my air filter is stock, should be all I need to do? Please advise.
ORIGINAL: John TN
ORIGINAL: liam51
I did check my plugs when I winterized and they were burning white. Bike is running way too lean so in the spring I will have the dealer install a SE race fueler. He said this will richen up my EFI. Got a great deal on Ebay. Keep your eyes open.
A little off subject, but with todays unleaded gas/oxidizers/additives, you will get a white reading, you can't really read the plugs like you could with leaded fuel. You have to get a reading off the exhaust with 02 sensors of what the AFR (Air Fuel Ratio ) numbers are and make the adjustments to the map richer or leaner. If you have a SERT installed and then have it dyno tuned by a good tech, you should get optimum performance with the correct AFR adjustments made.
nboeger4
Jun 9, 2012 08:06 AM
Supercell68
Nov 13, 2010 11:39 PM
dhc8guru
Nov 9, 2007 07:42 PM
s8norr
Oct 22, 2007 11:24 AM
07ultra07
Dec 19, 2006 01:06 PM
