Slow start
Old Dec 4, 2024 | 05:10 PM
  #41
702's Avatar
702
According to my 2019 owners manual, diesel engine oil works fine. Rotella is a diesel engine oil, right? Not so sure about his viscosity choice.
Old Dec 4, 2024 | 06:25 PM
  #42
NorthWestern's Avatar
NorthWestern
Originally Posted by Badger&Boar
Rotella is a DETERGENT oil.
You do NOT want to put it into an H-D.
Normal operational deposits.
Use Amsoil spec'd for Moto (V-Twin 20-50) , Lucas, I think Royal Purple stuff is OK too..
Back in the day I think it was Kenny Roberts who said; if you got a $10 head, wear a $10 helmet, go for it!
But all modern engine oils have detergents. Granted, modern diesel multi vis oils have a healthy additive package to suspend particles over extended drain intervals, but why would that be harmful to a V-twin?
I am curious what exactly is different about the additive package in the Rotella that would make it a no-go, there are no deposits that we would actually need ??
Old Dec 5, 2024 | 05:56 AM
  #43
KK0G's Avatar
KK0G
Old Dec 5, 2024 | 05:59 AM
  #44
Uncle Larry's Avatar
Uncle Larry
Curious, eh? I'm curious HOW you believe an oil set for diesel trucks and cars, is good for 2 wheeled gasser V-Twin?!?! Wow!
The great oil debates. Go ahead, put Rotella in your H-D, it's not my $$$ or bike or free time or budget or retirement $$$ or..... ! Good luck!
Might want to refer to Reply #45 in this thread
Old Dec 5, 2024 | 06:45 AM
  #45
702's Avatar
702
I showed you facts, and you were asked to do the same. If you can't do it, then you should say so.
If you truly believe HD engines require non-detergent oil, you might consider doing some research.
I used non-detergent 30w in my 1964 Corvair. It did a pretty good job at stopping oil leaks. The OP's bike isn't from 1964, and doesn't require a non-detergent oil.
This is mostly real men here that don't parrot what their uncles sisters best friends boyfriend said, and this isn't one of those laughing stock Facebook tech pages.
Old Dec 5, 2024 | 07:12 AM
  #46
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Another spammer for amsoil posting technical junk science.
Old Dec 5, 2024 | 07:43 AM
  #47
702's Avatar
702
It always amazes me how many people drink that kool-aid. It's oil, the bike doesn't care.
Old Dec 5, 2024 | 08:44 AM
  #48
hattitude's Avatar
hattitude
IMHO.... Amsoil has always seemed more like a marketing cult that uses their "club" to offer a discount to club members on their high prices....
As Groucho Marx once said, “I wouldn't want to belong to a club that would have me as a member”
Old Dec 5, 2024 | 10:22 AM
  #49
702's Avatar
702
Very interesting.
Post #45; the very NEXT SENTENCE after the highlighted section in the Owner's Manual says: first chance you get, take that oil OUT.
I can explain to you what that means, but I can’t understand it for you. So you just go on being an Amsoil fanboi.
Old Dec 5, 2024 | 11:10 AM
  #50
lp's Avatar
lp
Not here to argue but I've been using diesel oils (including Rotella) for 70K on the present bike and also in the last 8 bikes without issue. Many have. If you do a search on the forum you'll see many using it. It's just oil.
It's fine in the engine, but like many other oils, and because it contains friction modifiers, it's not recommend for use in the Primary (clutch plates).
Guess it's Winter.
