Looking for advice to install radio/speakers in 05 cop glide
Old Dec 6, 2024 | 07:40 AM
Ant31's Avatar
Ant31
6th Gear
Default Looking for advice to install radio/speakers in 05 cop glide
Looking for any advice on installing a radio and speakers in a 05 FLHTPI. I’ve heard the cop bikes aren’t pre wired for a radio. I can turn a wrench but when it comes to wiring I’m clueless. I have a radio and speakers, I have the bracket to mount the radio. Do I need an amp? How did you go about wiring yourself?
Old Dec 6, 2024 | 09:49 AM
KK0G's Avatar
KK0G
The answer to your first question is easy, no you don't need an amp. The second question is a BIG question that I'm not sure how to answer. If you're truly clueless when it comes to wiring as you stated then I'd suggest you consider hiring a professional.
Old Dec 6, 2024 | 12:15 PM
Gunnysgt's Avatar
Gunnysgt
Having owned two police model Harleys I can tell you they do have a different wiring harness than the standard models. If you can read a wiring schematic you could see what you need on the net but if you're wire challenged I suggest you let a pro do it.
Old Dec 6, 2024 | 02:36 PM
Oko's Avatar
Oko
Maybe try a post over here:
https://www.hdforums.com/forum/audio-systems-153/
Old Dec 7, 2024 | 07:12 PM
decencyxdefied's Avatar
decencyxdefied
If you want it to sound decent at highway speeds you need an amp. Go to the audio section next.
bigbike
May 2, 2018 11:50 AM
shakak
Aug 13, 2013 10:04 PM
Bonzaiii
Audio Systems
Oct 22, 2012 07:19 AM
Cabocarl
Nov 15, 2010 07:17 AM
MX558
May 1, 2008 07:28 PM
