A little problem I can't find
Old Sep 7, 2007 | 11:23 AM
05lux's Avatar
05lux
Default RE: A little problem I can't find
You never said what type of rims you have? If it is a spoke rim check to see if the spokes are loose. Also check rim run out.
Old Sep 7, 2007 | 11:41 AM
MyBluOx's Avatar
MyBluOx
I have Mag rims.
ORIGINAL: 05lux
Softtail Bob's Avatar
Softtail Bob
If the tires check out ok then don't forget to check the neck bearing. My brothers bike had a loose neck bearing and I could watch the backend sway back and forth going down the Hwy,.
Old Sep 7, 2007 | 11:47 AM
Scooter_092196's Avatar
Scooter_092196
When they mounted the tires, there isn't one on backwards by chance is there? I've seen that happen a time or two. Just throwing out ideas....
Old Sep 9, 2007 | 08:23 PM
MyBluOx's Avatar
MyBluOx
Well, It turns out that I had bad rear wheel bearings.
All fixed now.
Jeff
Old Sep 10, 2007 | 05:11 AM
Scooter_092196
Glad you found out what it was and got her fixed.
ryderbiker
Dec 10, 2012 06:36 AM
Joltergeist
Aug 13, 2012 01:41 PM
overhead
Sep 4, 2010 08:22 AM
Compo48
11
Mar 25, 2009 05:58 PM
flynavy
May 7, 2008 12:12 PM
