Disconnect ABS?
Old Oct 26, 2025 | 08:17 AM
hattitude's Avatar
hattitude
Originally Posted by bcool
Good morning, everyone. Just a follow up on my original post. I had a slight pulsating on the rear brake that was not the ABS kicking in but had always thought the ABS was too sensitive even before the pulsating began.
I replaced the rotor, went to organic pads, (previously ran HH pads) and flushed the brake fluid system and now can report the rear brakes perform much better, more stopping power before I have to brake hard enough to activate the ABS.
I honestly believe the HH pads were too sensitive (grabby?) and the organic pads are the way to go on the rear. I still run HH on the front and it works well.
Thank you for all of your suggestions and replies.
Barron
Just FWIW....
The majority of the time the brakes pulsate, not from ABS, it's due to a warped rotor....
Did you happen to check the rotor you replaced?
DR. V-TWIN
Mar 6, 2014 03:51 PM
Timmy B
Nov 5, 2011 10:20 PM
Bigbob88
Aug 7, 2011 06:47 PM
Jerry1834
Apr 6, 2011 07:15 AM
cawcop
Feb 22, 2011 06:41 PM
