2003 Ultra transmission problem
Old Sep 8, 2007 | 12:23 PM
hawg53's Avatar
hawg53
Default 2003 Ultra transmission problem
I have a question for you guys. I have a 2003 Ultra and after46,800 miles the transmission disentegrated. Most of the gears stripped and the main shaft and counter shaft are stripped. Is this a problem with this transmission? The service rep at the dealer said it is a common thing. He said I was lucky it lasted as long as it did. I can not believe a Touring bike would have this kind of problem after just 46,800 miles. Any of you guys had this problem before? Thanks
Old Sep 8, 2007 | 01:05 PM
glide's Avatar
glide
Default RE: 2003 Ultra transmission problem
They tell you everything is common and "they all do that". It's a sign of a dealer/mechanic that doesn't know jack.The 03 trans was a good unit, problem is that some used syn3 or an engine oil in it and that isn't the best for a long life. Use of a gear oil is recommended over an engine oil regardless of the rating system they use for the two oils.
What oil were you running in your trans?
Old Sep 8, 2007 | 03:26 PM
hawg53's Avatar
hawg53
I had syn3 in it. But I have been using that or Amsoil for that past 4 years. What should I be using?
Old Sep 8, 2007 | 03:31 PM
1flhtk4me's Avatar
1flhtk4me
I would usea dino or syn. gear oil.
Old Sep 8, 2007 | 06:44 PM
glide's Avatar
glide
ORIGINAL: hawg53
I'm sure that had something to do with your failure. Even HD stopped usingsyn3 in the trans in 04-05 .Use a gear oil in the transmission. Mobil1 75/90 or 75/140, redline, belray, or any other good gear oil.
Old Sep 8, 2007 | 06:48 PM
drdiesel1's Avatar
drdiesel1
I run Mobil 1 - 75W-140 in bothof mine. Now you should upgrade to a 6 speed Cruise Drive trans.....Yeah Baby....
Old Sep 8, 2007 | 06:56 PM
Yogibear's Avatar
Yogibear
I hate to sound like too much of a dimwit, but are we saying NO Syn3 in trans?
Dino or specialty gear oil better??
Dennis
Old Sep 8, 2007 | 06:59 PM
glide's Avatar
glide
ORIGINAL: Yogibear
Dennis
You have the idea now yogi, use a good gear oil.
Old Sep 8, 2007 | 10:07 PM
peddler's Avatar
peddler
Not sure if you are serious about the 6 speed cruise drive suggestion. I don't beleive the TC88 is compatible with the 6 speed cruise drive tranny. The TC88 can be bolted to a 6 speed SE tranny or a Baker DD5/DD6.Excellent proven quiet choices.
Old Sep 8, 2007 | 11:40 PM
drdiesel1's Avatar
drdiesel1
ORIGINAL: peddler
Yes. I was serious abouta 6 speed.Didn`t really think if would fit a Cruise Drive or not.. If your replacing a 5 speed complete, thenyou should replace it with a 6 speed...IMHO
