Missing and rough idle
Old Dec 21, 2025 | 07:15 PM
JordanJim's Avatar
JordanJim
Default Missing and rough idle
I have been gojng threw everything i can get my hands on. Checked all connections and found no lose or crowded one's. And Its now showing code p0505 and that code is not in the manual. If someone could tell what that code is for i would greatly appreciate it.
Thanks Jim
Old Dec 21, 2025 | 07:17 PM
CoolBreeze3646's Avatar
CoolBreeze3646
Thanks Jim
P0505 Idle speed control unstable
https://www.fuelmotousa.com/p-29661-...ble-codes.html
Old Dec 21, 2025 | 08:29 PM
Max Headflow's Avatar
Max Headflow
If the other codes are gone, I'd check for a manifold leak. Missing O ring on the tmap sensor, manifold seals and any other hoses going to the manifold / throttle body. I'd also check the Throttle Control Actuator connector.
Old Dec 22, 2025 | 08:39 AM
JordanJim's Avatar
JordanJim
Im not sure what I did. But its running fine now. I reset the ECM a couple of time and disconnected the battery and couple of time and let it sit for about 40 minutes each time and the the last time i reset the ECM and started it it ran fine no missing and ithe idle was fine. Like I said not sure what made it straighten out. And want to say thank you to everyone that give me information and things to look at. I really do appreciate it.
Thanks Jim
Old Dec 22, 2025 | 01:22 PM
Mr. Mike's Avatar
Mr. Mike
Well good for you!
Take it out for an hour and see how it performs. Then do it again tomorrow.
Old Dec 22, 2025 | 01:46 PM
Max Headflow
IIRC this is a later TC. Could the issue simply been the On/off/on/off/on thing where the ECU needs to learn where the 0 throttle position is?
Old Dec 22, 2025 | 09:47 PM
JordanJim's Avatar
JordanJim
I took about a 40 minute run tonight and it did fine. No missing and when I came to a stop it idle just fine. And when I get off tomorrow I will take another ride. I did the on/off deal and after I did it I would start it and it was the same and after the third time it started up and went to a normal idle. So I think it just took it a minute to reset or the first couple of time I didnt do the reset right.
Thanks for all.the help Jim
HVDyna
Twin Cam Motors
19
Aug 24, 2023 08:41 AM
minar
Sep 26, 2018 04:04 PM
chaos5
Sep 26, 2018 10:00 AM
scottdavis69@gmail.com
May 21, 2016 08:29 PM
steelrideFXDLI
Jul 28, 2011 06:23 PM
