Lost a screw
Old Mar 6, 2026 | 04:35 AM
Deep Sea MDV's Avatar
Deep Sea MDV
Default Lost a screw
I noticed I had a rattle/vibration yesterday near my windshield while riding to work. Once I got there, I saw that my throttle side screw was gone. Ok no big deal. Went and got another one. Put lock tight on it and snugged it up. The screw cost me a whole dollar. Now, after thinking a bit, I should check the entire bike. I would hate for something more important to rattle loose. Good thing I have this weekend off. Anyone found random screws or bolts missing? If so, where? I am literally going to check everything. (I probably should have been anyway)
Another thing I pondered was doing the transmission and the primary oil changes. It's getting to be that time. Just did the engine oil and filter.
2020 Ultra Limited 9200 miles.
Old Mar 6, 2026 | 06:18 AM
Red's Avatar
Red
Never use Loctite around plastic.....
Old Mar 6, 2026 | 06:21 AM
CoolBreeze3646's Avatar
CoolBreeze3646
Don't be surprised that when you go to remove that screw (depending on the type of Loctite/strength) that the threaded insert in the fairing breaks loose and spins within the fairing.
Old Mar 6, 2026 | 08:07 AM
Hoyt 1911A1's Avatar
Hoyt 1911A1
Been adding a SMALL drop of blue loctite to my windshield screws for years on two different Electra Glides (as mentioned being careful not to let any get on the plastic). I should mention that I'm an audio guy. I've had the outer fairings off of my bikes more in a year than most folks would in ten. Never had one of those brass inserts come out. Also never had one of those windshield screws come loose either. It don't take much loctite, just a little. Also when reinserting clean the old loctite off of the screws before reapplying to keep from over torquing. It also keeps water out of the threads and keeps them from rusting.
I suspect the reason those brass inserts come out is over tightening. YMMV.
Old Mar 6, 2026 | 10:07 AM
Deep Sea MDV
I used blue loctite. Hopefully no issue there. Hoping for no issue if and when I decide to swap out the windshield
I will go over everything this weekend and check it all tight. Hoping it was a one off type of thing.
Old Mar 6, 2026 | 04:11 PM
Cosmic Razorback's Avatar
Cosmic Razorback
Community Influencer
Active Streak: 30 Days
Yeah I would really be afraid of using LT on those with inserts in plastic.
The Rushmores are better than the older models as for the inserts. But I would not take a chance.
Torque them to the proper Torque and check them at least once annually and you'll never have an issue.
Old Mar 8, 2026 | 07:43 PM
TimP 117's Avatar
TimP 117
Best to do the original torque at the upper range of what the service manual recommends and when you do your yearly check set your torque to the lower range. This way you will know if it loosened up and you won't over torque or break the LT bond on your fasteners.
Old Mar 10, 2026 | 08:04 AM
Hoyt 1911A1
I can imagine if someone used a large drop that spread past the threads iinto the plastic it would be a problem. I use a super small drop and work it into the threads of the screws with my fingers and let it dry before assembly. Certainly if someone wants to be extra careful they could stay away from it, but I've got so much junk under the fairing in my bike I need things to stay put for the long haul.
lownslow
Knuckle Head
Sep 16, 2023 04:53 PM
3rdEyeStreetGlider
Jul 27, 2017 01:16 PM
Sandcrab
Feb 5, 2011 01:38 PM
keith t
Exhaust System Topics
Mar 31, 2010 10:08 AM
kbear
General Topics/Tech Tips
Mar 29, 2009 10:23 PM
