I have a device that shows the effective internal resistance of lithium polymer cells.
It is measured in milli ohms, a very small number.
It affects cold cranking amps and is part of what load testing shows.
A perhaps simple test is to have a very accurate resistor and voltmeter. The resistor is applied and the voltage is measured. There will be a difference between what the resistor should draw to what current is actually drawn. The small difference will be the internal or effective internal resistance.
That difference in current can then be used to compute the resistance.
There is no correct number as there are too many variables, like chemistry, capacity, temperature etc'.
It directly affects cranking capacity, and a good indicator of age - higher is worse .
I have a battery analyzer, and it's a very handy tool that will measure cranking current and internal resistance in mΩ .
I record the measurement for a new battery , and gives a good indication when to replace.
As for how much resistance is too much, it can vary depending on the type of battery. For example, a healthy lead-acid battery typically has internal resistance values ranging from a few milliohms to about 20 milliohms. If you start seeing values significantly higher than that, it might indicate that the battery is aging or has developed issues.
I wouldn't try checking it with your ohm meter. Just feed it with about 13-14 DC maintenance juice. Don't feed it all the time however. Let your motorcycle do it's thing.
As for how much resistance is too much, it can vary depending on the type of battery. For example, a healthy lead-acid battery typically has internal resistance values ranging from a few milliohms to about 20 milliohms. If https://tropical-casino.com/ you start seeing values significantly higher than that, it might indicate that the battery is aging or has developed issues.
High resistance can lead to poor performance, making it harder for the battery to deliver the necessary power. If you're testing your battery and see elevated resistance, it might be worth considering a replacement or further diagnostics to ensure your vehicle runs smoothly. Keeping an eye on these values can help you avoid unexpected failures down the road.
Finding "recommended" values has required quite a search. A search for internal resistance in motorcycle batteries uncovered this guidance. Below 10 milliohms is a good battery, 10 to 15 is marginal, and above 15 means it will let you down in the near future. Nowhere in my search was the effect, if any, on the charging system of high internal resistance. High resistance may be what contributes to voltage regulator and/or stator failure when trying to stretch that last season out of an old battery.
