Exhaust nuts
Old May 3, 2026 | 09:19 PM
LQQK_OUT's Avatar
LQQK_OUT
Originally Posted by Addicted to Chaos
Shouldn't have to do anything to keep them from loosening up, just make sure they are one time use and you will be fine.
I've lost a few exhaust nuts over the years. I'm guessing they vibrate off. I now use a 5/16-24 jam nut on top of the exhaust nut. Haven't had a problem since I started using the jam nut.
https://www.lowes.com/pd/Hillman-5-1...-Count/3058797
Old May 3, 2026 | 09:23 PM
Rounders's Avatar
Rounders
If it happened to me, I might to. But just never happened to me
I have found 1/4 drive ratchets work good for this.
Old May 4, 2026 | 07:13 AM
Fritz Franz's Avatar
Fritz Franz
I have followed the torque sequence stated in FSM on my '06 TC through every header removal/reinstall, stock and ProPipe and never had an issue with loose header nuts. I'm gonna get those brass Colony nuts just because (brass!).
Old May 4, 2026 | 08:47 AM
skydude426's Avatar
skydude426
Any time I have the header nuts off or loose, I torque them to the service manual specs. After the first ride and the bike has cooled down, I retorque them. Then again, after the second ride and the bike is cooled down, I retorque them one last time. So far, I haven't had a problem with one coming loose (knock on wood).
Old May 4, 2026 | 09:05 AM
glasspilot's Avatar
glasspilot
I've never had a problem with the nuts coming loose or being hard to come off. My problem was one stud frozen in the head. The stud threads had been damaged and I wanted to replace it. I never could remove it so I just threaded a new nut on the damaged threads and it never loosened. Now it's a mute point because the engine has been replaced with a S&S T111 engine!
Old May 4, 2026 | 10:11 AM
The Big Papa's Avatar
The Big Papa
Default Loosening
Originally Posted by Mongo1958
Looking for the size of the exhaust nuts at the heads. I want to double nut them to prevent them from loosening up.
Thanks
Loosening is the least of the problems. Can't get them out is more common.
Old May 4, 2026 | 11:46 AM
Mongo1958's Avatar
Mongo1958
This is why I needed the size. I plan to use them as a jam nut. Just installed them.
Old May 4, 2026 | 10:24 PM
Addicted to Chaos's Avatar
Addicted to Chaos
Originally Posted by MotoJockey
Which ones are you saying should be one time use? The steel ones or the brass ones? I've never changed out the steel ones on any of my bikes and have used them plenty of times. Just a tiny bit of never-seize and good to go. Never used the brass ones, but curious about them tho........
Steel. Never tried the brass ones...
Old May 4, 2026 | 11:03 PM
MotoJockey's Avatar
MotoJockey
Copy..... just checkin.
GOGOBECK
EVO
16
Jan 10, 2024 08:07 PM
GREENOHAWK69
EVO
Nov 17, 2023 01:21 PM
rculbertson102
Dyna Glide Pictures
Dec 24, 2014 09:36 AM
Jersey_Marine
Aug 4, 2013 02:55 PM
craigffb
Aug 17, 2010 02:43 PM
