Not trying to be a snob but I would just go to the dealer and get one..16715-83. I'm sure they still stock them.. They were used up through 2017 as far as I know .
The main thing aside from the dimensions, where ever you source them, make sure they're grade eight, minimum 125,000 PSI tensile strength. Otherwise you'll be right back where you are now.
Ive seen these snapped off before and grade 8 will thread right out if they were grade 5 they probably wouldnt have snapped, but a tough job to get em out if they do!
So I guess I need to order online or drive to the burg!
Amazon, where you can find almost anything and get it the next day. No specs but website is listed and if in doubt, give them a call or order direct from the source. https://twistedchoppers.com/shop/exh...n-cam-engines/
