pinion gear flhtc
Old May 13, 2026 | 06:45 PM
HD1989's Avatar
HD1989
2nd Gear
Default pinion gear flhtc
Hello need some advice for 1995 flhtc starter pinion gear. The pinion gear i pulled out with jackshaft is 9 tooth. Ring gear is 66 tooth. Parts book # parts are 10 tooth . Obviously someone has been in there before i bought bike a 3 years ago. Ring gear is bolted on. Piniongear is done. Jack shaft is broke. I may have caused that as I hit the starter with primary cover off. So not being original setup for the year is the 9 tooth pinion sufficient with the 66 tooth ring gear.? Is there advantage to reverting back to 10 tooth with 102 t ring gear?
Thanks for you advice.
jerry
Old May 14, 2026 | 09:09 AM
Max Headflow's Avatar
Max Headflow
The 9/66 starter ratio is supposed to be stronger than the 10/102 setup. The gear teeth are larger.
Technically 10/102 is a lower gearing.
If the 66 tooth ring gear looks good and you are not having any issues starting, I'd simply go with a new pinion. If not I'd go with 10/84 Compufire pinion/ring but only because I've used a number of them and they are easy to get.
Old May 14, 2026 | 12:29 PM
HD1989's Avatar
HD1989
2nd Gear
Thankyou for the quik reply.
Iwill get the new pinion
Just not sure of why a 95 had 93 pinion sprocket , so someone has been in there before me
thankyou
jerry
Old May 14, 2026 | 01:48 PM
cwhite6's Avatar
cwhite6
thankyou
jerry
I believe I may have one at home. I bought a 1995 Dyna starter and they sent me the complete jackshaft and everything. I installed a BDL belt drive that uses a different one. I can check when I get home this evening and count the teeth on it. If I have one, you are welcome to it. I have no use for it. I just looked at my parts book and mine is probably 10T, but I will check.
Old May 14, 2026 | 04:35 PM
HD1989's Avatar
HD1989
2nd Gear
Thankyou I will watch for your post
I live in Ontario Canada
Old May 14, 2026 | 09:13 PM
cwhite6's Avatar
cwhite6
The one I have is 10 teeth. You are welcome to it if you want it. PM me a mailing address and I will send it to you if you want it.
Old May 15, 2026 | 05:30 AM
HD1989's Avatar
HD1989
2nd Gear
Thankyou for the generous offer. I think I will have to pass on it tho because the ring gear is 66 tooth. I am not sure that the gear and teeth will match. The ring gear is in very good condition. I hope someone will benefit from your generosity.
Thanks again
jerry
kenpojrg
Custom Models
Mar 3, 2026 06:59 PM
FroggyFatBoy
Jul 2, 2014 05:18 PM
revnrob
Feb 25, 2014 03:48 PM
raiderluke402
Dec 27, 2011 10:37 PM
JustDave71
Jul 14, 2010 09:15 AM
