Changes on Ultra 07 to 08?
Old Sep 21, 2007 | 11:32 PM
62trvler's Avatar
62trvler
Default Changes on Ultra 07 to 08?
I asssume by reading other posts that the following changes are true...
6 gal tank
IDS Drive
Seat
Electroic throttle
Brakes
Wind deflectors
How about any engine or tranny mods?
??different cams
??larger throttle body
Old Sep 22, 2007 | 02:06 AM
dawg's Avatar
dawg
Default RE: Changes on Ultra 07 to 08?
ORIGINAL: 62trvler
6 gal tank
IDS Drive
Seat
Electroic throttle
Brakes
Wind deflectors
??different cams
50mm throttle body and the induction module is different. I found this out when I tried putting a Big Sucker on it and found out I had to go with the new 08 SE air cleaner kit. The ECM has changed also and is now located under the seat.
Old Sep 22, 2007 | 08:36 AM
The Old Man's Avatar
The Old Man
I did not know about the throttle body changes etc.. the catoluge spec shows a jump from 45 mpg to 54 mpg. I thought that the primary gearing might have changed to get that increase as the tranny ratio's have stayed the same. What are you guys getting for mileage on the 08's?
Old Sep 22, 2007 | 08:42 AM
Punisher's Avatar
Punisher
Cant really tell yet, only have 400 miles on it so far. Seems to suck fuel though, dont have a # to back it up. Oh another change for the list, the PBR Belt Buckle tank emblem had been reduced in size. (or maybe its just the larger tank that makes it look smaller
Old Sep 22, 2007 | 08:43 AM
62trvler's Avatar
62trvler
I believe the ECM went under the seat due to the new ABS. I wonder if a non ABS bike will still have the ECM located in the old position?
I have a 08 non ABS on order but if they are going to be hard to modify I may cancel. I ordered it before they published the throttle by wire so waiting to see what becomes available. I mainly just want to do a filter/slipon/program on it and let it flow a little better.
Old Sep 22, 2007 | 08:44 AM
Punisher's Avatar
Punisher
Dont forget the Fly-by-wire throttle, and the adjustable little wind wings. Would the throttle body increase make them sound better? Different exhaust? Mine sounds great, cant wait to hear it after a few thousand more miles!
Old Sep 22, 2007 | 01:40 PM
Opossum's Avatar
Opossum
Best mileage I've gotten yet was 38 mpg... only 1600 miles though and no tune mods yet.
Old Sep 22, 2007 | 01:52 PM
electaRICK's Avatar
electaRICK
diff between the 07 and 08,,, hmmmmm let me think,,,
on the 08 there is NO...
Pinging
nut toastin heat
clatter,
popping
chatter
pitter,
patter,
very little wine,
tickin
clickin
under load going to explode
5th gear screetch
destination outta reach
does have...
smooth accel
good vibes
more fuel cap
its tight
its right
abs , cant be beat!!
lovin time in the seat
the bike and Ihave once again became ONE!!!!
Old Sep 22, 2007 | 02:17 PM
MNPGRider's Avatar
MNPGRider
H'mmm, haven't tried that yet!
Old Sep 22, 2007 | 03:41 PM
Fishguy001's Avatar
Fishguy001
who'd a know it . Rick's a poet
