CB static back through helmet headset
Old Sep 22, 2007 | 10:24 PM
Grayhawk's Avatar
Grayhawk
Default CB static back through helmet headset
My cb statics back through my helmet headset when I push the button to use the cb. It only doesn't it when the bike is running. It doesn't do it when hte key is turned on or on accesory. Has anyone had the push to talk switch go bad on there bike?
Old Sep 22, 2007 | 11:09 PM
SoCal_Pappy's Avatar
SoCal_Pappy
Default RE: CB static back through helmet headset
Think there was a thread here a few days ago that addressed that same issue??? Don't have the link... Might try a search... I think John from J&M helped out....
Old Sep 23, 2007 | 12:27 AM
goodbirds's Avatar
goodbirds
Check the shielding on the cable. Should be grounded well.
Old Sep 23, 2007 | 07:49 AM
choochoo's Avatar
choochoo
Lot of things it could be.
But yes it's possible the head set cord is bad.
The cord should have a rf shielding in it and if faulty could cause the static/
Sounds like what'shappening is you're picking up ignition noise through the system.
So check wiring down in the control pod too.
Old Sep 23, 2007 | 11:18 AM
JMJOHN's Avatar
JMJOHN
Sponsor
Grayhawk ,,,,,
while you are trnasmitting and hearing the static, reach back with your other arm and wrap your hand around the CB antenna ,,, and tell me if the noise goes away ,,,
make sure you know which antenna is which ,,,, JMJOHN ,, john@jmcorp.com ,,,,,
__________________
JMJOHN,,,, www.Jmcorp.com ,,,, send email direct to John@Jmcorp.com for your HD-Forums VIP Discount Promo Code.
Old Sep 23, 2007 | 07:56 PM
Grayhawk's Avatar
Grayhawk
When I transmit and holdthe cb antenna, the cb still statics and pops and cracks. I doesn't make a difference!
Old Sep 23, 2007 | 11:03 PM
JMJOHN's Avatar
JMJOHN
Sponsor
well ,,, shoot ,,, unfortunately then I don't have a clue what is wrong ,,,,,,,
could just be a bad CB ,,,,,
IRIDE4me
Oct 9, 2018 10:56 PM
striper.seeker
Audio Systems
Jul 26, 2016 01:14 PM
Flintshooter54
Jan 22, 2012 07:52 PM
bhunter00
Oct 16, 2010 10:17 PM
Deepsouth251
Jan 17, 2009 12:02 PM
