Fluids change for Winter
Old Sep 28, 2007 | 11:59 AM
IronLegend's Avatar
IronLegend
Default Fluids change for Winter
Like a lot of others I will be storing my RKfor the winter soon and am going to have an independant shop change the fluids. TheoneIgo tois 20mi. away so when I leave thereto ride it back home would I need to be concerned with any amount ofcontaminationin the new fluids that would have just been put in it?
Also, I was going to have themuse a 20W-50 dino mcl oilfor the engineinplace of theH-D synthetic that's in it now and change the filterthen when Spring arrives switch back to the synthetic engineoil again (you know just leave the cheaper oil in it for thewinter). Any thoughts on this? Thanks.
Tom
Old Sep 28, 2007 | 12:11 PM
petemac's Avatar
petemac
Default RE: Fluids change for Winter
Nope.
Why not change the filter with the oil and when spring comes, all you need to do is change the oil. Why leave a dirty filter on all winter that you're just going to change amyway?
Old Sep 28, 2007 | 12:52 PM
Sreynold1's Avatar
Sreynold1
I change mine at the end of fall, ride it home(15 miles), ride the same oil next spring until it's due for the next oil change. Why all the oil changing? AmI missing something?
Old Sep 28, 2007 | 12:56 PM
IronLegend's Avatar
IronLegend
I was planning on having the engineoilfilter changed next month when the tranny & primary fluidsare replacedas well as putting dino oil in theengine for the winter (cheaper),then in spring changing the filter again when the synthetic oil goes in the engine for the riding season, or will I be changing the oil filter one too many times here? I'm under the impression that dino and syn don't mix well together and there would still be residual oil in the filter during the change?
Tom
Old Sep 28, 2007 | 01:04 PM
IronLegend's Avatar
IronLegend
Sreynold1
I guess what your saying is that when I change the engine oil and filterin the fall then it will still be Ok toride as isnext seasoneven after sitting thru the winter?
If that's the case then when I have the other two fluids changed Iwill replace the filter andengine oil with the synthetic at that timeas well, ride it home and store it in the shed for the winter then come spring just take it out and ride it like that. Sounds reasonable.
Old Sep 28, 2007 | 01:17 PM
stro1965's Avatar
stro1965
I change it when it needs changed. Even in winter, bike never stays parked for too long.
Old Sep 28, 2007 | 01:54 PM
Windup08's Avatar
Windup08
Its just a waste of money to change oil in the spring if you changed in the fall. The oil sitting in the bike is as good as new come spring. I've done this for a lot of years on every bike I've ever owned without any problems.
Classicfc
Jun 19, 2012 01:40 PM
40 Knuck
Mar 25, 2010 02:10 PM
john1238
Oil Archive (no new posts)
Jan 14, 2010 11:04 PM
joromu
Jan 12, 2009 12:28 AM
anubisss
Jul 11, 2007 09:00 PM
