Accessory Plug Std on New Bikes
Old Sep 29, 2007 | 06:44 PM
HarlyFan's Avatar
HarlyFan
Default Accessory Plug Std on New Bikes
On all the new bikes I was told that they are coming standard with a accessory plug hanging down from the frame. I thought this would be great to b e able to plug a battery tender or electric clothing into however it looks like it is a different size plug connector than a standard battery tender plug is. Has anyone figured this out yet? Also if you plug into this harness is that particular item controlled by the Accessory switch on the dash for on/off?
Old Sep 29, 2007 | 06:48 PM
stapler101's Avatar
stapler101
Default RE: Accessory Plug Std on New Bikes
The accessory plug under the seat, in front of the battery, is what I plugged my Zeplin seat into.
And yes, I learned the hard way, it is controlled by the acc switch on the dash.
Old Sep 29, 2007 | 08:13 PM
choochoo's Avatar
choochoo
Why do you need a battery tender?
Afraid someone might steal it fro under your seat?
Old Sep 29, 2007 | 08:25 PM
stu07hd's Avatar
stu07hd
My 07 Ultra has a plug for a battery tender wired in from the dealer that hangs down on the right side of the bike. It also has a pre-wired plug that is tied into the Acc. switch that is under the seat in front of the battery.
Old Sep 29, 2007 | 08:40 PM
Hogwallop's Avatar
Hogwallop
My 07 RKCustom came with the accessory plug hanging from under the seat on the right side. It's live without the need to turn on the accessory switch.
Old Sep 29, 2007 | 08:43 PM
masterblaster's Avatar
masterblaster
I have a 07 Road King Classic, never noticed the accessory plug but will look tomorrow.
Old Sep 29, 2007 | 08:44 PM
brewdog's Avatar
brewdog
So is mine on my Ultra. You can see it in the photo. My plugis live all the time.
[IMG]local://upfiles/14162/FA91ADE9F6824FD3B17D1CA78D98335E.jpg[/IMG]
Old Sep 29, 2007 | 08:47 PM
HarlyFan's Avatar
HarlyFan
Mine might be under the seat and I don't know it also. The battery tender cablecomes out on the right side zip tied to the frame. You are suppose to be able to plug several different accessories into the plug that Harley provides but I'm not sure how that is suppose to work...........
Old Sep 29, 2007 | 08:54 PM
MNPGRider's Avatar
MNPGRider
Check your Harley catalog. You can plug in one accessory, or buy a splitter and plug in more than one, controlled by the accessory switch. The Battery Tender connection is separate, and is wired direct to the battery, with its own in line fuse.
The accessory connection under the seat runs such things as the heated seat, or the air zeppelin.
Old Sep 29, 2007 | 09:03 PM
HarlyFan's Avatar
HarlyFan
ORIGINAL: MNPGRider
WHere is it in the Harley Catalog? Do you have a part number and price?
