fast idling
Old Oct 2, 2007 | 07:22 PM
greyghost2000's Avatar
greyghost2000
Stage II
Default fast idling
Can anyone tell me why all of the sudden my bike seems to be idling faster than normal.I have a 2000 road king fuel injected.
Old Oct 2, 2007 | 07:45 PM
treym's Avatar
treym
Default RE: fast idling
I have the same issue. It takes a long time to idle down when cold and on occation
it idlesitself up quite a bit. I was going to take mine in and see if it has anything to do
with the throttle postioning sensor. It was my only guess.
Old Oct 2, 2007 | 07:48 PM
Fla Glide's Avatar
Fla Glide
I have the same problem every now and then.. It will idle @ about 2k, I'll bump the throttle and normally settles down..04 EG
Old Oct 2, 2007 | 08:29 PM
rbabos's Avatar
rbabos
Could be something simple like the temp sensor behind the horn in the front head having poor connection.
Ron
Old Oct 2, 2007 | 09:10 PM
choochoo's Avatar
choochoo
first things first.
check the head temp sensor connection clean and tight.
Pull any trouble codes
clean and tighten the battery cables at both ends.
could be something else too. But start with these basics first.
Also check the idle air control motor.
Also realize if the outside air temp where you're at has been cooler than normal lately then it's a normal happening.
Old Oct 2, 2007 | 09:11 PM
Jazz56's Avatar
Jazz56
Had the same problem on my 98 fuel injected Road King not long ago. High idling took forever to drop down and some random idle spikiing. After posting on the forum and speaking to a few local mechanics I replaced the engine temperature sensor, then re adjusted the high and low idle settings . Problem solved. My guess is this is your problem. Easy to fix yourself if you have a manual. Only thing is the sensor cost $100 and is not returnable. You might want to give it a try .
Old Oct 4, 2007 | 10:59 AM
greyghost2000
Stage II
thanks for the advice folks. Havent been home to try any suggestions but will let ya know if it works.
Old Oct 4, 2007 | 12:48 PM
steelhead's Avatar
steelhead
As I understand it, this is a somewhat common issue with theMagneti-Marelli FI bikes. I've never had it happen (knock on wood) on my 01 RKC but have been told by more than one person that it is common.
Old Oct 4, 2007 | 01:00 PM
rome304's Avatar
rome304
had same problem after inner fairing painted had idle adjuster problem.
Old Oct 4, 2007 | 01:09 PM
NCCopBikeRider's Avatar
NCCopBikeRider
Any chance you have been using the star wheel under the throttle as a "Crusie Control" and have not loosened it up to the point that the idle settles back down?
YRMV
tkenney2nd@yahoo.com
Oct 26, 2016 03:32 PM
carlgrover
EVO
Feb 6, 2011 07:37 AM
gtojets
EVO
Feb 28, 2010 08:34 PM
thehueg
Aug 15, 2009 04:20 PM
Slyde
Nov 28, 2007 02:35 PM
