ECM question
Old Oct 3, 2007 | 12:27 AM
sifularson's Avatar
sifularson
Default ECM question
Went for a test drive today on my newly finished stage 1 update. BS air cleaner, Torres true duals, PCII, and V&H ovals. Bikes runs great. Stopped by a dealer in my area to get a part and got into a conversation with the parts guy. He told me that I didn't need the PCIII and all I needed was a stage 1 flash of the ECM. He told me that several people have been in with PCIIIs that were running poorly. They removed them and had their ECMs flashed and their bikes ran great.
To do this, I could put the O2 sensors back in, remove the PCIII, and have the flash for around $150.
Is there anyone here who has done exhaust, etc. and had their ECM flashed? How did it work for you?
Thanks for any input that will help.
Steve
Old Oct 3, 2007 | 12:43 AM
drdiesel1's Avatar
drdiesel1
Default RE: ECM question
The ECM flash is a canned calibration the dealer make 100% profit on.
Buy a SERT or other tuner box. Ditch the PCIII(IMO)
With a few bucks more you can control all the ECM functions and run the O2`s like you should.
By removing the O2 sensors you relying on the Box to control AFR. If that PCIII fails you motor could be toast.
You get what you pay for. IMO a PCIII is junk.
I run a DTT/WEGO IID on my 07 FLHX and the SERT on my 08 FLHTCU. No need to rely on anyone to tune my bikes. The dealers are useless IMO.
Buy something you can tune and control yourself. It`s not hard to do and learn. Be self reliant and save yourself some big money in the long run. Spend it right the first time and save from there.
Old Oct 3, 2007 | 12:56 AM
pounder35's Avatar
pounder35
good post here my bike goes in friday for the dealer download all im doing and im in calif by the way is the stage1 wont this useless download be enough??? i've seen and heard dont wast your money on this get the sert or whatever.
The stealer says it will be good enough so i can get the AC. anything is better then stock.
Hey Steve how do you like your ovals i was thinking about adding those as well
Old Oct 3, 2007 | 01:03 AM
drdiesel1's Avatar
drdiesel1
ORIGINAL: pounder35
Like I said, you get what you pay for. If your only interested in the cheapest way out. That's fine, but I think if you spend the 450 up front for the SERT, you`ll save money in the long run and be able to tune you bike to whatever mod you choose at anytime in the future.
You can read and clear codes, record a 1/2 hour of real-time data(this is a diagnostic tool), change AFR, injector size, engine displacement, timing charts and anything else you can think of related to tuning. It has 3 tuning modes. 2 are used without a DYNO. It`s a DIY setup.
I like to do it myself. F the stealer's. They are programmed for one thing and one thing only. TO GET YOUR MONEY....[:'(]
Old Oct 3, 2007 | 02:08 AM
glens's Avatar
glens
Well, yes, the dealers are mostly in it for the money. What would be the point otherwise unless they were independently wealthy or something?
The dealer's "download" is basically a change of the VE (volumetric efficiency) tables to reflect the stock engine wearing specific intake and exhaust components. It will maintain both EPA compliance in the cruise ranges and correct operation in the other ranges.
Of the two (mufflers, intake airbox assembly) the intake is the one that really needs the VE tables modified. In that sense, your dealer was correct that it will be "good enough". The ECU will most usually accommodate muffler changes so those being the specific part for the particular download aren't so critical. It would be best, though to use what the factory used in developing the download.
The SERT is the best option of those mentioned, but being in CA I doubt it actually is an option in the first place. At least not at your dealer's place of business.
This stuff ain't kindergarten-level knowledge, so don't feel bad if you don't grasp it, but it ain't to the level of rocket science, either, so you likely can if you put your mind to it.
The major downside to the PC is that it throws away some of the neater functions of the stock ECU, which is a step backward. I use the PC at the moment and it's sure better than nothing. In fact I believe its the best thing short of SERT or one of the replacement ECUs. It decidedly ain't no junk no matter what. And in light of your exhaust plumbing changes, it's decidedly better than the dealer download. They certainly don't have a download for the exhaust system and you could well get into trouble in the long-run if you go that route (the download instead of the PC).
Old Oct 3, 2007 | 02:20 AM
sifularson's Avatar
sifularson
ORIGINAL: pounder35.
The look and sound are what I expected. The chrome is perfect. I really like the look from the rear. Here are some pics.
[IMG]local://upfiles/14366/A949A1BE836542588FC5BC08637E3FD0.jpg[/IMG]
[IMG]local://upfiles/14366/AF14BAEDCCAD4BB0A406B1C1CE82B7BA.jpg[/IMG]
[IMG]local://upfiles/14366/3CF91C88D80247DFB4F0BBEEEF9C111B.jpg[/IMG]
Old Oct 3, 2007 | 02:25 AM
sifularson's Avatar
sifularson
ORIGINAL: glens
Thanks for the reply. What are some of the "neater funtions" you mentioned.
Old Oct 3, 2007 | 02:53 AM
glens's Avatar
glens
see https://www.hdforums.com/m_2282331/m...tm.htm#2283055 for a short version
Old Oct 3, 2007 | 04:37 PM
sifularson's Avatar
sifularson
bump
Old Oct 3, 2007 | 04:50 PM
drdiesel1's Avatar
drdiesel1
ORIGINAL: sifularson
bump
The SERT and A/M ECM`s allow total control. You control it with your PC without the dealers B/S
flhtc07ok
Jan 18, 2008 08:41 AM
Bagginit
Dec 30, 2007 10:21 PM
Drexor69
Jul 5, 2007 08:40 AM
PlanoRider
May 2, 2007 10:36 PM
dr.phatkins
Apr 9, 2007 11:36 PM
