NEED SERT MAP
Old Oct 8, 2007 | 10:27 PM
Indianspringsaz's Avatar
Indianspringsaz
Default NEED SERT MAP
Anyone have a SERT map with my setup (below) that doesnt ping and runs good? My bike runs good but does ping. I couldnt even use 6th this weekend with a head wind, even at 80 mph. Pinging.
Old Oct 9, 2007 | 12:00 AM
drdiesel1's Avatar
drdiesel1
Default RE: NEED SERT MAP
Just change the timing at the TPS/MAP/RPM values the engine pings at. Read the SERT manual that comes with it.
Mark the throttle at 75%, 50%, 35 %, 25% 12% and Zero. Record the setting when it pings and what RPM`s your at and change the cells by dropping4 to 5degrees. After you have stopped the ping, reset the same fields up by 1 to 2 degrees until it just starts to ping. Then drop them by 2degrees and your done.
That`s the best part of having a SERT. You can fix things and adjust ityourself. You could also activate the real-time data recorder and monitor it with that as well.
Time to read and learn how to adjust and tune the bike for yourself. That`s the most gratifying wayto me. If you need help...Just ASK US.
That`s what this forum is for. To tech and be taught/learn to DIY.... IMHO..
Old Oct 9, 2007 | 06:04 AM
TickTock's Avatar
TickTock
Which cal are you running now?
Old Oct 9, 2007 | 06:10 AM
DonnyI's Avatar
DonnyI
If you initially had it dyno tuned by a competent shop, take it back and insist that they get it right. Best investment would be a DTT.
Old Oct 9, 2007 | 10:23 AM
drdiesel1's Avatar
drdiesel1
ORIGINAL: TickTock
I`m running an 08 FLHTCU with SERT, SE-A/C and SE-Slip-On`s. My map will not be anywhere close to what you need.
Old Oct 9, 2007 | 10:37 AM
Indianspringsaz
I have a custom cal. in it now. Runs like a raped ape solo, but 2up and gear, cant use the throttle in 4th, 5th or 6th. Wife only weighs 110 lbs.
Old Oct 9, 2007 | 11:27 AM
drdiesel1's Avatar
drdiesel1
ORIGINAL: Indianspringsaz
Drop in a SERT map and see how it runs....Test different maps to find one that works. Or like I said before....Tune the timing table of the map your using. JMO
Old Oct 10, 2007 | 06:18 AM
TickTock's Avatar
TickTock
which cal is it tuned from?
Old Oct 10, 2007 | 03:17 PM
Indianspringsaz
I just got back from the Dyno. Ping is gone. Runs good again. 72.5HP, 88.5TQ. Nice smooth curves.
HDF Tech
Mar 29, 2013 02:58 PM
JonnyD
May 13, 2009 05:23 PM
wglide69
Apr 6, 2008 09:52 PM
Roadhog02
15
Jan 26, 2008 09:32 PM
rpt63
Feb 16, 2007 06:28 PM
