Road Glide D&D Fatcat install
Old Oct 13, 2007 | 09:11 AM
whoop72's Avatar
whoop72
Default Road Glide D&D Fatcat install
Putting the D&D fatcat on my 07 roadglide this weekend. If you have already done this, anything that you learned that I need to do or watch out for in the install?
Thanks!
Old Oct 13, 2007 | 10:02 AM
Trock's Avatar
Trock
Default RE: Road Glide D&D Fatcat install
Exhaust gaskets
Old Oct 13, 2007 | 11:17 AM
whoop72's Avatar
whoop72
Picking up a set of screamin eagle exhaust gaskets this am. Thanks
Old Oct 13, 2007 | 11:27 AM
Wally's Avatar
Wally
I learned a good trick from PhilM.
Drive yor bike up onto a piece of 2 by 6 so that both wheels are on it.
When you put the kick stand down the bike will lean over more. A friend on the left of the bike would be a good idea, just in case.
With the bike over like this, you won't loose any or much transmission fluid when you remove the transmission side cover to swap out the exhaust mount.
And use a torque wrench, brake cleaner and blue loctite on the bolts when reinstalling them.
Old Oct 13, 2007 | 08:33 PM
whoop72's Avatar
whoop72
Thanks!
Old Oct 13, 2007 | 08:48 PM
Wally's Avatar
Wally
High heat silicone between the header and the muffler, and check the bolts at the heads after you ride it the first time and again in a few hundred miles.
Ask me how I know.
CoastlineAmps
Jun 9, 2011 06:34 PM
tinsley
Exhaust System Topics
Oct 19, 2010 04:24 PM
twhill3
Mar 3, 2009 06:16 AM
Sann_X
Nov 9, 2007 01:11 PM
classicjade01
Oct 24, 2007 09:38 PM
