Does not always start
Old Oct 15, 2007 | 09:27 PM
Chicago Spike's Avatar
Chicago Spike
Default RE: Does not always start
Oooo, another possibilty, I'll try the tapping if/when it happens again
Old Apr 6, 2008 | 12:00 PM
Pilgrim2's Avatar
Pilgrim2
Stage III
Same problem here. Solenoid is stuck so I just lightly tap the end of the solenoid with a screwdriver handle and it starts. ( embarrassing )
The local stealer says they cannot help me unless it does it right at the dealership, and it is very intermittent.
I am a tad pissed with them.
'07 Ultra
Old Apr 6, 2008 | 05:10 PM
choochoo's Avatar
choochoo
Does it do it only after you disarm the security system?
If so try NOT arming the security system for awhile, it may have trouble.
Also the PCiii according to prior posts in the past has been known to cause
problems if you wait for the full cycle before starting.
Try starting as soon as you turn bike on.
Something to do with the way the PCiii receives power and cycles itself.
there could be other issues but let's sort them out one at a time.
Old Jul 26, 2008 | 09:37 AM
dhchicago's Avatar
dhchicago
I have an '08 Road King that just developed the same issue. At first I thought it might be in the switch but, I have a feeling there's a loose connection between the bars and the ECU because when I turn my bars hard to the left,,,,,it starts. I'm due for my 5000 mile check so I'm going to tell the dealer and hopefully they'll fix it.
Old Jul 26, 2008 | 10:00 AM
77Tulsa's Avatar
77Tulsa
My 07 ultra is in the shop now for cranking over and you can here the fuel pump but no lite off. It quit while I was riding as i shifted to 2nd gear after start up and would not restart!
Old Mar 10, 2012 | 06:06 PM
Pilgrim2's Avatar
Pilgrim2
Stage III
Default Solved
Better late than never.
I fixed the no start problem. ( a long time ago)
It was the solenoid plunger getting stuck. Just take it apart and put a very fine
coating of silver anti-seize on the cupped fiber stopper that bottoms out inside
the solenoid.
That was 3 years ago and it has never happened again!
speedyrob
Sep 24, 2018 01:10 PM
stbob07
Sep 11, 2012 09:16 PM
Lex_Talionis
Nov 22, 2011 09:10 PM
thomasf59
Jul 19, 2007 03:02 PM
needaz
Aug 1, 2006 04:00 PM
