No Start 07
Old Jul 12, 2007 | 07:49 AM
thomasf59's Avatar
thomasf59
Default No Start 07
Turned on the key, bike in neutral, turned the run switch to on, waited for the fuel pump light to go off, hit the start button the engine would not turn over.
Went through the routine againand it started.
Aside from the negativebattery cable being loose and wires on the starter loose is there anything elseto check, could the key not have been in the on position all the way. Any ideas?
Got to work and shut it off tried to start again it poped right off.
Not boing able to trust the bike is a bad thing.
Tom
Old Jul 12, 2007 | 08:24 AM
jterp's Avatar
jterp
Default RE: No Start 07
Was the bike hot or cold? If it's real hot there can be compression built up in the motor that can make it hard to turn over...
Old Jul 12, 2007 | 08:41 AM
thomasf59's Avatar
thomasf59
It was cold, turned over no problem after work yesterday, just got on it this morning to go to work and nothing when I hit the start button.
tom
Old Jul 12, 2007 | 09:29 AM
thomasf59's Avatar
thomasf59
I was thinking of this would the key FOB cause the engine not to crank if the battery were low in the FOB?
TOm
Old Jul 13, 2007 | 12:19 PM
ronn39's Avatar
ronn39
Similar experience with my '04 while on a recent trip, which I reported on here earlier. Make sure that miseraable little white molex plug going to the starter selenoid and hiding behind the oil lines on the right side hasn't worked loose. It gets intermittent and then eventually quits all together.
Old Jul 19, 2007 | 02:02 PM
Bon_Scott's Avatar
Bon_Scott
5th Gear
I had similar problem with my 93. I first thought it was in the kill switch. Cleaned it up, tested , no problems. Turned out to be the main circuit breaker. If the '07 is anything like '93 there are 4 breakers under the seat. The main is obvious. They should all read low, like 1 ohm, But my main tested out at 11.6. No problems since I replaced for $4.
Old Jul 19, 2007 | 02:25 PM
ride2tires's Avatar
ride2tires
seems as though StargazerXT12 just had the same problem???
Old Jul 19, 2007 | 03:02 PM
mr.hammond's Avatar
mr.hammond
something easy ,im,sure.
Tg waldog
Jun 19, 2018 12:40 PM
Chicago Spike
Mar 10, 2012 06:06 PM
CCNitro
Mar 28, 2010 03:20 PM
Yonaton
General Topics/Tech Tips
Nov 14, 2008 06:37 PM
