Zumo Bluetooth not Compatible w/HD Mic?
Old Aug 26, 2008 | 08:21 AM
Merlin's Avatar
Merlin
Originally Posted by wassup8687
Are you using this with the Harley headset?
If so what is the interface used to make it work?
Yes and No, Actually the J&M headset with the Harley 6/7 pin adaptor cable.
Yes, I plug the into tank dash console where the Harley headset plugs in.
The interface works with the stock Harley headset for making phone calls.
Crystal clear phone calls at 70+mph
Old Sep 17, 2008 | 07:09 PM
Merlin's Avatar
Merlin
Default Harley Headset - Bluetooth - Zumo - Interface
Here are some pictures of what I did...
I ran the power, audio out and mike in wires inside the handlebars.
I did the "AUX jack in the back of the HD radio" mod.
I installed two Radio Shack 1/8" couplers under the Powerlet Powerbar.
This allows for a quick disconnect of the Zumo and Zumo bike mount.
(This way the I can also remove the Zumo bike mount for safe keeping)
I ran the mike in wire inside the bars and under the tank dash to the interface.
The two wire connections on the bottom left go into the handlebars.
The two patch cable wire connections on the right connect to the Zumo.
I used the Powerlet Powerbar and 2 1/2" Techmount Powerbar stem w/quick disconnect.
It works with both the bikes radio speakers and/or the console headset.
What is amusing is turning on the bikes speakers and playing the phone call so all can hear.
Yes, MP3, GPS directions, bluetooth and CB all work with the HD console headset or bikes speakers.
Crystal clear calls at 70+MPH.
I can add a link to a WAV file I made of the Headset/Zumo/bluetooth/interface sound quality if you would like.
Old Sep 17, 2008 | 08:57 PM
JKL05ULTRA's Avatar
JKL05ULTRA
Who makes the interface, what model is it, and where can I get one?
Thanks!!
Old Sep 17, 2008 | 09:00 PM
Jim Dawson's Avatar
Jim Dawson
Still don't know what interface you're using.
Old Sep 18, 2008 | 11:12 AM
Merlin's Avatar
Merlin
Default Zumo 550 - Console Headsdet - Bluetooth - Interface
UPDATED JUNE 28th:
I changed out the prior interface that I was using and just installed the HD BLUETOOTH BOMM from
http://home.comcast.net/~jbissonette1/site/
It arrived within two days of ordering.
It took less than 10-15 minutes to install
The install:Two wires and a plug.
It works GREAT!
It's so clear folks that I speak to on the phone don't even know I'm on the bike.
I use it with:
Zumo 550 and HD stock center console w/stock HD headset.
Old Sep 18, 2008 | 12:37 PM
dlrshort's Avatar
dlrshort
I bought and sold my 550 within a week because of that issue. The problem is that the external mic is on the car mount only not on the unit itself. So when you have the motorcycle mount you're out of luck and need to have the head set. I hate bt headsets and have not had very good luck with them. The Nuvi Garmin GPS units, at least some of them, have a mic on the unit itself and you can use a Ram motorcycle mount for it. The only thing I don't think they are weather proof like the Zumo.
Old Oct 31, 2008 | 01:43 PM
wkenddad's Avatar
wkenddad
Where did you get the handlebar mounting clamp seen in your photos?
Old Nov 1, 2008 | 08:55 AM
Merlin's Avatar
Merlin
Here is the info on the Powerlet and Techmount w/quick disconnect.
https://www.hdforums.com/forum/touring-models/191007-zumo-powerlet-techmount-quick-disconnect.html
TwoBlue02
Dec 13, 2015 08:25 PM
Red-line
Audio Systems
29
May 10, 2014 10:56 AM
BadBilly49
Audio Systems
Jun 7, 2011 11:54 PM
The Old Man
Dec 25, 2007 10:14 PM
mark10
Product Reviews
Nov 7, 2007 08:14 PM
