I have an 08 Street Glide and am supposed to have an accessory outlet under the seat. Does anyone know where this is? Can I plug a pigtail in it for my trickle charger and if so where can I get a pigtail? Mike [sm=americanasmiley.gif]
If you are talking about hooking up a battery tender to your acc plug......NO, you cant do that. The plug should be next to your battery, some have had to pull their battery out to find it. Its for a powered acc. that will operate from your acc. switch on your dash.
The battery tender I bought from the HD Dealer came with a pig tail that I had to install on the battery and it hangs down just under the seat to hook up the tender.
Left Side Cover. Pull it off. Under the fuse panel. A plug with a cap on it. The plug itself is attached to the panel with aSlide type attachement. Slide it out forwward. Remove the cap.
There it is in your hand.
sooo, that acc switch if for accessories huh? No Kiddin'! And all this time I've been telling everybody that was my air conditioning control!
Thanks for all the replies. I've been trying to put some miles on it before winter comes so I haven't had alot of time to tinker around. Looking forward to adding some accessories but this bike is pretty much badass stock!!!
Mike
My 08 Street Glide has a pigtail for the battery tender already installed on the right side cover frame rail.Right side as your sitting on the bike.Just pull cap off to use! Jrsess
