WTF Rear Pipe glowing red
Old Oct 24, 2007 | 03:26 AM
GlennsGlide's Avatar
GlennsGlide
Default WTF Rear Pipe glowing red
Hey Guys
Burnt my leg quite badly the other day when I accidently touched the left header on my Bassani Powercurve headers, so I applied some fibre glass
wrap around the left down pipe & right donut sections to try and reduce the heat coming through heat sheilds.All went well until I fired it up as per the instructions to melt the wrap to the headers and after about 3 minutes I noticed the donut section was glowing red near to head. Is this normal or do I have a promlem, as far as I can tell the front header doesn't glow red.Could it be caused from the fact that the pipe sweeps around at a fairly tight radius.
Thanks
GlennsGlide
Old Oct 24, 2007 | 03:49 AM
PapaTravis's Avatar
PapaTravis
Default RE: WTF Rear Pipe glowing red
I have seen both of my pipes glowing after a ride, when the garage is dark. Makes sense that the rear would be the first to light up, as it gets the least amount of oncoming air. I have also read here where others have experience this, so I wouldn't worry to much about it. If it is major concern to you, you might try shooting it with an in fared temp indicator. Do you have an oil temp gage? You might check just to make sure you are running in the correct temp range, IMO.
Old Oct 24, 2007 | 07:37 AM
TX_RG's Avatar
TX_RG
My bet is that the rear cylinder is running way to lean. A friend had the same problem with the rear header, once they richened it, it was like night and day.
Old Oct 24, 2007 | 07:58 AM
hdmikeshirley's Avatar
hdmikeshirley
My rear pipe used to glow red after every ride, but I've not seen the front glow red, yet. When the bike was stock, it glowed a bright orange. When I first got the Sert and tried a canned map it still glowed, but a duller red. I've since richened the AFR even more, so I don't get a glow at all now after rides.
Old Oct 24, 2007 | 08:40 AM
glens's Avatar
glens
It probably only needs mixture attention at idle more than anything.
If the pipes are wrapped with insulation, where's the heat going to go? It'll try to dissipate where it can, and if it can't, it'll be carried right into the muffler, causing problems there next.
Old Oct 24, 2007 | 05:27 PM
Paniolo's Avatar
Paniolo
GlensGlide,
Although commonly done, wrapping the header pipe is not recommended by any major header manufacturer. Call most makers, and they will say that it voids the warranty.The wrapretains the heat even more, and superheats the piping. It's done for race engine applications that are torn down and redone on a regular basis. I wrapped the rear head pipe on my Hooker True Duals a couple of years ago for the same reason. Heat. The heat was so intense, it toasted the left sidecover. I took the wrap off after one year to do some work on the bike. Large metal flakes came off with the wrap revealing the pipe underneathto be very deteriorated. So I did what I should have done in the first place, and sent the pipes out to be ceramic coated. With all the good coatings these days from companies like Jet-Hot and the like, there really is no reason to wrap the pipes to cut down on heat. Most folks do it though for appearance.
The other thing that helped me was getting my afr set correctly. Remember, the TCs come real lean and hot from the factory.
Good Luck.
Mark
Old Oct 24, 2007 | 05:37 PM
oldhippie's Avatar
oldhippie
Any bike running so hot that the pipe is glowing is a problem in my opinion.
It is probably running extremely lean due tohigh volumeair intake and exhaust. Have you dynoed this set up? How do you know you have the AFR set properly?
Old Oct 24, 2007 | 05:41 PM
Retired_Ted's Avatar
Retired_Ted
My 2000 BMW R1100RT had headers with no heat shields. The headers would glow red which was easy to see at night. Completely normal for that bike and, I bet any HD too. I would find a friend whose bike was running normally and ask them to start their bike and fast idle it for 2-3 minutes in the dark just to see if the pipes would glow.
Old Oct 24, 2007 | 05:52 PM
Geezer Glide Bob's Avatar
Geezer Glide Bob
If you don't want to use header wrap, then think about a qualitity ceramic coating INSIDE and OUT! I had mine done and now after 10 minutes of hard riding I can grab any part of the pipe. No more tink tink tink (chrome cooling)after the bike is shut off either!
Old Oct 24, 2007 | 06:23 PM
rockdoc's Avatar
rockdoc
I second all the 'running lean' replies. I recently had a simlar issue...not on my SG but on my son's dirt bike he races. He put all this new crap on it (ooops....I meant to say 'mods') and next thing we knew, the new header glowed red and the bike was overheating. He wanted me to buy him a fancy new set of aftermarket radiators, I wanted him to rejet the carb and richen the mixture up. I won and the bike ran much cooler (no more glowing pipe). He crashed the bike the next time he raced, separated his shoulder, and crushed his stock radiators. I bought the fancy new radiators afterall.
cgmartine
Feb 26, 2016 10:55 PM
champ198
Oct 22, 2010 12:23 PM
62pan
Exhaust System Topics
Jun 12, 2010 08:54 PM
cuffnum
Jun 8, 2009 07:30 AM
jackster007
Jun 13, 2006 12:11 AM
