95 big bore kit
Old Oct 25, 2007 | 10:38 AM
hawg50's Avatar
hawg50
Default 95 big bore kit
im in the process of doing a 95 kit on my 06 ultra.it has andrews 37g gear drive cams,stage 1 air filter,and rinehart true duals.can anyone suggest a download from the power commander site that might work on my build until i can break it in?i plan on a dyno tune after a few hundred miles.
Old Oct 25, 2007 | 11:11 AM
NCCopBikeRider's Avatar
NCCopBikeRider
Default RE: 95 big bore kit
Dyno Jet's web site has all the information you will need to make an informed decision
Old Oct 26, 2007 | 11:19 AM
hawg50's Avatar
hawg50
bump
Old Oct 26, 2007 | 11:28 AM
fishafly's Avatar
fishafly
ORIGINAL: NCCopBikeRider
CLICK HERE
Old Oct 26, 2007 | 12:30 PM
Bigredone's Avatar
Bigredone
Why not let the Dyno Tech break it in and tune it at the same time then you don't have to load a standard map.
Old Oct 27, 2007 | 06:09 AM
msocko3's Avatar
msocko3
ORIGINAL: hawg50
Are you putting on some ported heads? I had a 95" TW37 stock heads build for about 9k miles. Wasn't real thrilled with it so I pulled the cams and now their sitting in the box and I went with a complete HQ build with their porting and 0039 cams, now I'm happy.
Old Oct 28, 2007 | 08:13 PM
hawg50's Avatar
hawg50
no,im staying stock on the heads,at least for now.maybe later i will do the heads(when i go to 110)
Old Oct 28, 2007 | 08:33 PM
PhilM's Avatar
PhilM
If you're sincerely considering somehting like a 110 at a later date, the 37 will get yanked at that time.
Running 37's in a Bagger with stock compression will not yeild much in the way of results. I have run 37's. They need more compression (9.5 ~ 9.7:1) to really work well.
Based on what you've said, there are several other cam choices that would be better for you and would make you much happier. I would consider HQ-0034 orAndrews 26 in a 95" with stock compression and heads. Trust me on that one!
In fact, anyone that knows me will be shocked by this one.... I would use a S/E 203 before I'd use the 37, in that configuration.
Old Oct 29, 2007 | 05:56 AM
msocko3's Avatar
msocko3
ORIGINAL: PhilM
I'd do either the 203 or the 204 before the 37. The 37 with stock heads was a big dissapointment. My dad has a 06 Ultra with 204's that would walk away from me down low when I had the 37's.
FL-kruzen
Oct 6, 2012 05:06 PM
ulclass10
Exhaust System Topics
Aug 30, 2012 05:10 PM
Billdoe
Mar 28, 2012 12:19 PM
FXDFan
Aug 4, 2010 05:17 AM
skday
May 22, 2006 09:58 AM
