07 UC fairing and putting it back on
Old Oct 25, 2007 | 03:22 PM
mark10's Avatar
mark10
Default 07 UC fairing and putting it back on
taking the fairing off - no prob
some of the holes don't line up when putting it back on
is there some secret or does everyone have to really push and stuff to get them to line up
Old Oct 25, 2007 | 03:28 PM
NICK56's Avatar
NICK56
Default RE: 07 UC fairing and putting it back on
PUT 2 SCREWS ON THE TOP SIDE IN FIRST (LOOSE) .
THEN TOP 3 OR 5 SCREWS.. LOOSE
THEN BOTTOM 2 SCREWS.. LOOSE.
MOVE FAIRING TO LINE UP SCREWS IN BOTTOM 2 HOLES.
2 PEOPLE WILL MAKE THIS EASIER...
THEN TIGHTEN ALL
Old Oct 25, 2007 | 04:18 PM
Harleypingman's Avatar
Harleypingman
There are a lot of wires inside the fairing; be sure they are put back to where they were. The main problem I have seen is wires getting loose (either connectors not placed on their mounting points, or wires that were zip tied being unzipped for working on the bike and not re-zipped) and having too much behind the headlamp.
Otherwise, I install the top center bolt first; then the other two top bolts; then the side bolts; then the lowest two. All are installed loose; then the lowest two are tightened; and, the remaining ones tightened. You can install the windshield with the top three bolts loose--makes it easier to get the first bolt started without the windshield in place.
Also, I always cover the fender when installing or removing the outer fairing. A buddy dropped his outer fairing on his '06 EG and caused obvious damage to the clear coat.
Old Oct 25, 2007 | 04:38 PM
jbhawley's Avatar
jbhawley
another tip...
put a couple old socks over the passing lamps when you remove/reinstall the outer fairing. It allows you to man-handle the fairing a bit more without having to worry about scratching the paint. Makes the job much easier.
benningtonr
2014-2024 Touring Models
19
Feb 22, 2017 11:12 AM
casique
Mar 13, 2012 04:20 PM
Jags93
Jan 4, 2011 03:51 PM
Spur56
Mar 26, 2010 09:14 PM
Manfire
Apr 6, 2008 10:05 PM
