Tmax problem
Old Oct 28, 2007 | 09:56 PM
sugarbear's Avatar
sugarbear
Default RE: Tmax problem
ORIGINAL: hennyk
Might sound stupid but what is a t max? What does it do?
It is a replacement ecm and programable with an auto tune feature. You don't need a dyno tune.
Old Oct 28, 2007 | 09:57 PM
cardboard's Avatar
cardboard
Notised if I was in 6th and tried to pull up on the shifter the 6th gear light would go out, I would shift back to 5th then 6th and it would come back on.
Old Oct 28, 2007 | 10:54 PM
SGDude's Avatar
SGDude
The 6th light thing is associated with then engine speed. I have the latest firmware and it was after loading it that the tach/speedo thing happened.
Old Oct 28, 2007 | 11:28 PM
Paniolo's Avatar
Paniolo
Today my speedo started "dancing" back and forth between 35mph, and 80mph. It's done this before too. It would hold steady for a second, then start dancing. This made the cruise control inoperative, and the automatic volume control on the radio go up and down too. Like the others, I had to pull over, shut the bike off, then restart it. It seemed to run okay after that.
I didn't know there was a firmware update for that. I hope it comes out soon.
Old Oct 29, 2007 | 07:16 AM
glens's Avatar
glens
Sounds like the thing's running on Windows. Yikes! I'm definitely going with the DTT...
Old Oct 29, 2007 | 07:34 AM
cardboard's Avatar
cardboard
Been running a T-Max on my Wide Glide for some time now. Haven't had a single problem with it. I will take the T-Max with auto tune over anything. Got a lot of friends with the T-Max on their bikes too.
It makes it run that good.
Old Oct 29, 2007 | 09:34 AM
cardboard's Avatar
cardboard
Cowboy Harley is suppose to be taking my Thundermax with A/T off my 07 Wide Glide. My 08 Electra Glide Standard has Drive By Wire. I called Zippers and they told me that they are working on a software update that should be out sometime after the 1st of the year to fix the DBW problem so I can use it on my 08 bike.
That is just what I wanted to hear.
Old Oct 29, 2007 | 09:36 AM
Bob's Avatar
Bob
ORIGINAL: bigdoghd
Just wondering if anyone running the Zipper Thunder Max(full system)has had a problem where the speedo & tack stop working.Alsothe check engine light and charging light came on. It was just after I got on the bike and I notice the problem.It appeared to run fine.I stop and shut the bike down and then restarted it and it was fine. Anyone else have this happen?
Yep... It's happened to me twice now with the "new and improved" 4.5 firmware.
I've submitted the problem to Zipper Tech Support.
ednigma
Sep 6, 2024 09:09 AM
MARCUSBEAR
Electrical/Lighting/Alarm
Oct 17, 2014 12:34 PM
Trek
Jul 15, 2011 09:57 AM
RNBONES
May 25, 2010 01:52 AM
rwalters
Oct 14, 2007 05:25 PM
