Leaking Bags
Old Nov 2, 2007 | 03:32 PM
Harleypingman's Avatar
Harleypingman
Default RE: Leaking Bags
+1 for bigheadted. The police bags usually have one or more holes in the fender side of the bag that need to be plugged; especially the left saddlebag because with the bike on the kickstand the left saddlebag's backside is more exposed. Otherwise, check the latch mechanism in the saddlebag lid (on the inside of the lid) to assure a tight fit between the shaft of the latch mechanism and the hole it passes through. Also, check to see if there is afoam donutunder the hockey puck; it fills the space under the hockey puck and is glued to thesaddlebag lid. You may need to remove the hockey puck to check this.
Old Nov 2, 2007 | 04:53 PM
AK_Hog_Herder's Avatar
AK_Hog_Herder
My Ultra hard bags were dry until the dealer installed rails and didn't silicone the screws. [:@]
Old Nov 2, 2007 | 09:36 PM
choochoo's Avatar
choochoo
Glad someone clarified he has the road king police.
Means he has the hockey pucks on top.
Had an 01 for 4 years.
Never did get them to stop leaking.
Tried o'rings and gaskets etc.
Best thing is a drain hole in the bottom so they drain when bike is parked.
Then plastic garbage bag liners.
cops don't normally ride their bikes in the rain (although it happens), safety hazard.
another option is to replace the lids and hinges and latches with the standard side latch.
arlington
Audio Systems
20
Apr 22, 2019 10:42 AM
TXJames
Dyna Parts
Aug 29, 2015 12:46 PM
TXJames
Aug 29, 2015 12:43 PM
KevinMark
Apr 2, 2008 12:12 AM
BruinsFLHRS
Mar 1, 2008 11:57 AM
