what cams to install with 103 kit
the 103 performs quite a bit better pure stock then a lightly modified 96,as did the 96 over the 88 to 95' mod,i thank you for the input,but after some 40 different harleys,i now want a fairly smooth low maintenance 103 with some decent power and torque,the 211 as i am told do not work well with stock compression,i was thinking between the 204,s and 255,s,i would like to hear thoughts
[/align]
There are tonsof sub (100/100) 103s out there because dealers want the labor rate and people bite on bigger inchis the performance solution withskinny cams, and do little else.
Here is my bike96with SE 211s, completely factory stock top, Bassani Headers, Reinhard Muffs, SERT, adjustable PRs..... Its just shy of 100lbs of Torque...pulls like a freight train from 2800-5800 RPM. When I got the bike back it felt liketo theseatlikea 50% increase inpower compared to bone stock,even though its nothing close to that kind of percentage gain.
My dealer buddyadmitted alot of 103s do not evenhit my dynonumbers because the buyernever puts the combination together right. And cams and tuningare going to be a large part of what you get out of this 103 and what if anything you do with the heads.
Who ever is telling you 211s do not work well in a stock 96 needs to put the crack pipe down. They are in the business of boring jugs and selling pistons and gaskets....Are you shooting formore performance then I dynoed? If not, then I made my point. If so, then you will need some head workthe 211s or slightly largeron that 103 IMHO.
I will make you agood guess the 204s in your 103 does not make my peaknumbers and runs out of breath early. Do not get me wrong here.......... I only pointing out you could have had some ball ripping straight upcurveperformance without spending the money on an overbore and new pistons.... I would have saved that, forwhen you wore out the top end you alreadypaid good money for. 211s as a FACTrocks in a 96!
Whats my reccomendation? Leave it 96, Port your heads, go SE 211s, Race Tuner, adjustable PRs, your favorite pipes and I guarantee it will put a smile on your face! I am thinking you will see over 90HP and easilyhit just over 100 Torque if you port heads.
Shoot a personal email to(Greg09997)https://www.hdforums.com/showprofile.asp?memID=33245 Greg has a Stock 2007SG, I let himride mine last weekend back to back..... I am quite certain he will gladly confirm the difference I am talking about, he nowplans to replicate exactlywhat I have done with mine. Best of all you can have it for less money and keep your brand newtop end. My Wireless throttle is now snappier then a Chua Chua!
I am hoping tohelp educate the money wasted on these 103s overbores!Itsbest left for a top end freshen.The 96will perform handsomely with some reallymildtweaks!
[/align]
http://www.latus-harley-davidson.com/dyno_charts.asp
Stock bore (for 88" & 96" motors) is 3.75". "Big bore" (for 88" & 96" motors) is 3.875". The size difference comes from the stroke. The 88" has a 4" stroke & the 96" has a 4.375" stroke.
The difference in bore from stock to big bore is actaully .125" (not .30 or 30 thousandths).
While is is true that more performance gain is possible from cams only vs bore only (both require tune), when "done right", the best results come from adding both cams & big bore (then there's heads, compression, etc). ALWAYS think "package", components need to work well TOGETHER, and not all of them do.
If I'm just talking to myself.... sorry to have wasted your reading time...
Hey, I enjoy learning new things that is why I'mhere.You and others have been a great source of knowledge for me since I've joined, so keep talking we are listening. thanks
And the point is combination, and the performance goals a person has.A 96 will perform handsomely with some minor mods and make many people happier then they ever dreamed possible and their wallets will be fatter.
I am really trying to help and not rain on someones parade decisionhere, but trying tosave them money and dissapointment.The impression I have was this was a 103 swap with Headersa Cert and a SE204.I am pointing out the goals in mind could easily be done with the 96. Good nice rumble idle, reliable, Tire shredding bottom end great top end with what I consider to be someminor mods. And easilyhit the goals identified by RDMHOUSTON with taking advantage of what he already has in the 96.
Lets us know how it turns out. I suspect it will satisfy you. But going the other route too would have been really satisfying and you would have had a bit more money in your pocket.
And thats my story.
What Donnylee did for his 96", I did with my 88" by adding HQ-0034 cams and left the motor otherwise stock, but with a good SERT tune. Far better performance than had I purchased an SE 95" kit.
Seven cubic inches is not going to make a meaningful (for me, anyway)performance difference if compression, head flow, and camming remain the same or are only marginally changed.
