just installed IDS
Old Nov 8, 2007 | 04:59 PM
redhill's Avatar
redhill
Default just installed IDS
I just installed my IDS from Zannottis. All Harley parts. I seem to have some what of a vibration at higher speeds that was not there before. Especially when I let off the throttle. Anyone else have that problem since putting on the IDS?????????????
Old Nov 8, 2007 | 05:03 PM
YodaddyKeith's Avatar
YodaddyKeith
Default RE: just installed IDS
nope,
Jack her up and recheck belt alignment and all.......Make sure to test her at high speed with clutch in and see if vibes go away.
Old Nov 8, 2007 | 05:08 PM
redhill's Avatar
redhill
how could the belt be out of alignment?? It is on the sprocket good?????
Old Nov 8, 2007 | 05:16 PM
YodaddyKeith
Aw come on.........You're are telling me you installed the IDS yourself yet you didn't see how easy it was to get the belt missalligned?
Old Nov 8, 2007 | 05:20 PM
redhill's Avatar
redhill
yes sir.. how is aligned??? just put it all back together and rode..............
Old Nov 8, 2007 | 05:30 PM
glebo's Avatar
glebo
as stated, it may be alignment. If everything went on ok, and no extra parts, you should be good. The alignment will affect the way the belt rides on the sprockets (pulley's) and also the way the brake pads sit on the caliper. Find a place to measure the center of the axle to a reference point equal on both sides. Don't forget to check belt tension also. The dynas had a little hole in the swingarm forward of the rear axle you could use it as a measurement point. I haven't dove into that area yet on my sparkly new road king..
Check, check, and double check. You may find something.
good luck
Old Nov 8, 2007 | 06:27 PM
voodoodrug's Avatar
voodoodrug
06 up impossible to mis-alighn ,,,I think? theres isa do-hickey thingy ramp whatchma call it that forces it in alighnment. My guess is now that your bike is smoother/quiter with the ids your hearing a non related item?
Old Nov 8, 2007 | 07:01 PM
Scootr's Avatar
Scootr
ORIGINAL: voodoodrug
The cams on the 07 make the alignment pretty easy. Check to make sure you put the spacers arein the right place and make sure the rubber dampeners are meshed together properly etc and it should be good to go. Like voodoorug says you may be noticing something non related now that it is quieter like I did. My licence place bracket was making a vibration noise that I had not heard before. Other than that I have not heard of anything else.
Old Nov 8, 2007 | 07:11 PM
glens's Avatar
glens
ORIGINAL: glebo
Find a place to measure the center of the axle to a reference point equal on both sides... The dynas had a little hole in the swingarm forward of the rear axle you could use it as a measurement point. I haven't dove into that area yet on my sparkly new road king..
A coat hanger, a "sharpie" marker, pop the chrome plugs out of your swingarm pivots, bend about an inch and a half right-angle leg on one end of the coat hanger and stick it into the pilot hole in the end of the swingarm pivot. Mark the center of the axle with the sharpie. Check the other side. My eccentric washers do not match side-to-side but the center distances between the pivot and shaft do...
Old Nov 8, 2007 | 09:11 PM
redhill's Avatar
redhill
It is not anything I am hearing or not hearing. It is actually a vibration I feel in the floorboards. Worse at higher speeds and decellerating..........
