Fullsac Performance
Old Nov 9, 2007 | 01:04 PM
Todd T's Avatar
Todd T
Default RE: Fullsac Performance
ORIGINAL: Gutman
The Fullsac system didn't do anything for the performance when you installed it. I have Dyno'd the three sets installed here and most made less power than original head pipe. with SERT only increased about 4 horse. No heat shield and so called ceramic coating come off inthe amount of time to test ride. Torres would be prefered. Don't compare a dual conversion kit with a true dual performance system. No comparison in price or performance. Pick your preference, not always cost.
That is leaving alot on the table there!
"I have Dyno'd the three sets installed here and most made less power than original head pipe." Less power where? and how much less? What did each one do (worst to best)? I know the obvious answer to this but please, do share your findings.
"with SERT only increased about 4 horse" which is it 3, 4 or 5? About dont cut it when using a dynamometer. Also, what map? canned or custom? who tuned it, how long did they work on it?
"No heat shield and so called ceramic coating come off inthe amount of time to test ride" Fulsac reuses the factory HS, were the directions to reverse the two heat sheilds too complicated to follow? ceramic coating came off; should have been a warranty issue. what was the outcome?
"Don't compare a dual conversion kit with a true dual performance system. No comparison in price or performance." So is this again using a canned map or custom. Who tuned it, how long did they work on it and how much HP and Trq was gained (Not about, but actual would be prefered).
A "Dual Performance System" comes with matching slip-ons at a higher cost to the consumer. What slip-ons where you using when you dyno'd and got the "about 4 HP". How many different brands and sizes have you data logged? Have you flowed (using a flowbench) the rear head pipe from a "performance system" and compared that to the factory head pipe after the fulsac conversion? wouldnt that be a more fair assessment of whether the fulsac shows an increase without factoring in slip-ons, canned vs. custom maps and so on?
Old Nov 9, 2007 | 01:14 PM
NCCopBikeRider's Avatar
NCCopBikeRider
What Todd said
Old Nov 9, 2007 | 01:20 PM
SaltyBagger's Avatar
SaltyBagger
I put the fullsac TD kit on my 88. But I wasn't interested in a performance gain. I did it because I was sick and tired of welding my cracked H-pipe every few months and the kit was a lot cheaper than a new one. It's been on for a year and a half and I haven't had to weld up that ratty old pipe since - mostly because it's in the dumpster.
Old Nov 9, 2007 | 01:35 PM
sugarbear's Avatar
sugarbear
ORIGINAL: FLuHX
What about the o2 sensor in the back pipe. Does the Fullsac accomodate that.
You have to order the set that has the bungs. I installed the 02 sensor before I installed the pipe. worked for me.
Old Nov 9, 2007 | 01:57 PM
RangeRat's Avatar
RangeRat
I wouldn't expect to see much HP gain by going from the stock head pipes with the "H" to after-market split dual head pipes. In fact, torque may well drop a little no matter which split dual set-up you go to since 2into1(on paper anyway) shouldflow a bit betterand the stock "H" setup ends up acting very much like a 2into1.
That said, I'm also not after more performance improvement (beyond PCIII with SEAC and V&H ovals) for now anyway. I am after bang for the $ on soundthough and split duals sound better to me.
The new link siflarsonposted shows an '07 setup with bungs for $300 so Torres folks have priced themselves out of the running. V&H Dresser Duals aren't all that much more and for a fewextra $, seem to be abetter choice. Fullsac is $190 though so......
Old Nov 9, 2007 | 03:13 PM
FLHT's Avatar
FLHT
You can watch e-bay for the Fullsac also. I bought mine on there for 129
Old Nov 9, 2007 | 03:26 PM
RangeRat's Avatar
RangeRat
I just thought of a related(?) question...
I have PCIII installed in my '07so aren't sensorsan option now (at least here in FL)? Thesensorsarestill installed in my stock pipesbut I believe (from what I see in other threads) that they are notused at all with PCIII. If that's right, then it might reduce Fullsac cost even more to just leave them in the stock pipes and go "bungless".
Sorry for potential hijack,not my intent, just hope for some clarification on Fullsac option.
Old Nov 9, 2007 | 05:24 PM
Domestic Violence's Avatar
Domestic Violence
SGTP- i see in your sig pic that you didnt 'flip' the heat shields. if you do, youll eliminate that cut-out portion where the "old" pipe joined the front header. simply reverse the shields so that each straight end meets and adjust accordingly at the muffler.
as far as the fullsac goes- it really is a great option for those of us who want true duals at a great cost and ease of installation. i wanted the balanced sound (and slight reduction of heat) when i installed mine (which took about an hour with a friend- 4 hands are better than 2)
Old Nov 9, 2007 | 09:09 PM
sifularson's Avatar
sifularson
ORIGINAL: RangeRat
I bought pipes with bungs in case I ever want to install a T-Max or similar system that uses the 02 sensors. Otherwise, I would do exactly that you suggested.
Steve L.
Old Nov 10, 2007 | 03:13 AM
RangeRat's Avatar
RangeRat
Thanks Steve.
Steve
