Anyone Having This Problem w/ Shifter?
Old Nov 13, 2007 | 04:49 PM
lp's Avatar
lp
Default RE: Anyone Having This Problem w/ Shifter?
Usually happens after washing the bike a bunch of times. Clean out the old grease in the shifter arm thing... thats the problem.
lp
Old Nov 13, 2007 | 04:54 PM
bobros's Avatar
bobros
Had same problem on an '06. Told the tech while it was being services. He know exactly what was wrong and fixed it under warrenty. I forget what he told me the problem was but it was a common repair.
Old Nov 13, 2007 | 07:43 PM
DB10881's Avatar
DB10881
I have the same problem with my '03, but only after it has set a few days...sounds like i need to do a little dismantle and grease job.. that or ride it more often.
Old Nov 13, 2007 | 08:11 PM
Woodchuck's Avatar
Woodchuck
ORIGINAL: dawg
Best thing to do is go out and get a 45 degree grease zerk. Take that zerk and replace the one in your steering neck so that you can gain easy access to grease the bearings at 10,000 mile intervals. Then with the zerk that you took out of the neck, drill and tap a hole in the shifter sleeve on the primary and install it there like the old EVO used to have. Then every once in awhile put a shot of grease in it and see how smooth your shift works. I have done that to the 04 and the 08.
I noticed that the zerk that was on my EVO shift shaft sleeve was "missing" on the '07. I didn't think much about it until reading these threads. I don't have any problem with a sticky shifter linkage but I think I'll install your mod so I can do a bit of preventive maintenance.
Old Nov 14, 2007 | 05:08 PM
rome304's Avatar
rome304
try search section has a lot of good info on this subject.
Old Nov 19, 2007 | 01:31 PM
ClutchCargopa's Avatar
ClutchCargopa
Looked into this issue this weekend and found several things. As mentioned the shaft that the shifter pivots on is in my opinion a poor design as others have also suggested. Having a touring bike I do get caught in the rain as well as washing my bike every other week or so, I noticed a build up of oxidation on the shaft. I also notice the possibility of capillary seepage of water under this shaft to cause this oxidation. Since the removal of the zerk valve it is either a necessity to install a zerk or periodically grease the shaft andcheck for this oxidation.
Having removed the shaft I cleaned the oxidation withscotch brite and reinstalled with anti sieze lub to allow for better shifting. The issue that I was having with sticky shifting has gone as a bad memory. Shifting is much smoother and more definate. I no longer have to assume I have shifted to the next gear. It is now literal as it was when the bike was new.
This winter I will take the time to install a zerk valve so I can grease this shaft during my maintenance schedule as I have added much to this outside the factory recommendations.
Old Nov 19, 2007 | 05:16 PM
Rollon's Avatar
Rollon
Mine was doing similar thing, i had the clutch adjusted and it works smoothly now.
Old Nov 19, 2007 | 05:23 PM
dirtdobber's Avatar
dirtdobber
I changed mine out for the kuryakyn chrome linkage with sealed grease fittingson each end. It has bearings. It shifts better and very smoothe. Since it is sealed wather cannot get in and looks much better.Only $39.95
http://www.kuryakyn.com/products.asp...ey&ci=2458
jim
Old Nov 19, 2007 | 06:27 PM
hogbag07's Avatar
hogbag07
Hi all
Thanks dawg a great idea with that right angle stearing head grease nipple.I just took the standard one out and it is dry This bike has had 3 services and a dry grease nipple ??? Thanks for the tip
cwsharp
Aug 22, 2022 11:54 PM
INJEKTER
Sep 12, 2015 06:33 PM
128auto
May 7, 2013 09:32 PM
namato1
Jul 28, 2011 07:58 AM
Lawdawg
Jul 29, 2005 05:27 PM
