leaking clutch cable
Old Nov 13, 2007 | 06:14 PM
streeter's Avatar
streeter
Default leaking clutch cable
Go figure, I put around 5k on my new glide this summer with no real problems. I put it away for theseason, changed the lube in all 3 holes................and now I have a leaker!!! The bike sits on the stand with the front a little lower and I guess the trans fluid has flooded the shift cable area causing it leak. I've heard of some issues of leakage due to a damaged Oring or bad crimp on the cable but I'm inclined to think that this might of been caused by the the angle at which it sits on the stand causing the area to be flooded with oil. I'll keep you posted on what I find.
Cheers
Streeter
07FLHX
Old Nov 13, 2007 | 07:18 PM
Bldr1000's Avatar
Bldr1000
Default RE: leaking clutch cable
Streeter: I have an 07 ultra and juwt noticed the other day that there is oil all over my clutch cable and frame just in front of the connection with the transmission. I will get it checked by dealer soon. It might be from when they serviced the bike and either spilled oil when draining or installing oil. Other thought was that it was overflow from cable lubrication. Just my observations....Bldr
Old Nov 13, 2007 | 07:56 PM
Retired_Ted's Avatar
Retired_Ted
Common problem - have the cable replaced under your warranty - it's defective and should NOT leak.
Old Nov 14, 2007 | 05:08 PM
rome304's Avatar
rome304
try search section has a lot of good info on this subject.
Old Nov 14, 2007 | 05:49 PM
hd2007's Avatar
hd2007
07 is under warranty , take it in for a free repair.
Old Nov 14, 2007 | 05:56 PM
wldbill's Avatar
wldbill
Same thing on my buddy's 07 RKC. The dealer may tell you it's nothing but that wont be true and it will get worse.
gonpce
Aug 2, 2017 06:05 PM
Inop
EVO
Feb 12, 2015 01:47 PM
Hundred Dollars
Feb 14, 2012 09:01 AM
bdjhog
Jun 14, 2011 11:41 PM
rcjtplt
Nov 3, 2007 12:40 AM
