LED tail light bulb
Old Nov 15, 2007 | 03:07 PM
odog's Avatar
odog
Default LED tail light bulb
I would like to replace the tail light buld with a LED buld, do I need a load equalizer for this I've heard yes and no...Someone help me please.
Thanx
Old Nov 15, 2007 | 03:48 PM
dawg's Avatar
dawg
Default RE: LED tail light bulb
Just the taillamp bulb, NO equalizer needed. If you do signals then you need an equalizer.
Old Nov 15, 2007 | 03:50 PM
gunrunner's Avatar
gunrunner
ORIGINAL: odog
Thanx
Why? most of those led bulbs are not as bright as a standard bulb.
Old Nov 15, 2007 | 03:52 PM
extech's Avatar
extech
Be careful which bulb you choose. The socket is mounted at an angle so if the LED bulb is the flat faced type you will actually see less light than a conventional bulb.
Old Nov 15, 2007 | 03:57 PM
texas steve's Avatar
texas steve
ORIGINAL: gunrunner
Thats exactly why you need a equlizer. The circut is looking for a specific resistance/current draw. When it sees less it thinks a bulb is broken. With LEDs they draw much less current and to the circut this appears as a broken bulb.
Old Nov 15, 2007 | 04:23 PM
framer's Avatar
framer
i was at the local stealership yesterday talking to the parts dude about this for mine. he said exactly what dawg said. just brake light NO brake and turns YES
Old Nov 15, 2007 | 04:28 PM
steveh326's Avatar
steveh326
ORIGINAL: texas steve
ORIGINAL: gunrunner
have to disagree with you. just the taillight, no equlaizer required. It IS required for the signals tho, without it, there is less current draw on the line, and the FLASHER doesn;t work properly, they flash too fast due to the lower current draw. Putting the equalizer in the line simulates the current draw from a regular bulb, and the flasher works normally.
Whether or not an LED taillight is brighter or dimmer than the stock taillight is more a reflection on the quality of the LED, 12v is 12v.
Old Nov 15, 2007 | 04:39 PM
StreetGlider56's Avatar
StreetGlider56
I have led's in my flashers on the rear, and added two more bullet lights on each side of the tri bar light. they work as one set is stop/running/turn snf the stock turn signals are now stop and turn.. here's some pictures...
[IMG]local://upfiles/11910/44DFAC39D9DB4976A33DF5F0CEB6D01E.jpg[/IMG]
[IMG]local://upfiles/11910/F2892106F305459991C5A08039601CF0.jpg[/IMG]
Old Nov 15, 2007 | 04:45 PM
07FLHRCMarinePatriot's Avatar
ORIGINAL: odog
Thanx
Before you buy check this out. I posted it after buying one from the dealer. https://www.hdforums.com/m_2256614/tm.htm
Old Nov 15, 2007 | 07:57 PM
soos's Avatar
soos
OK, let's see, I have LED's in my stop/brake light, rear directionals (wired as turn/brake lights), tourpak spoiler(wired as running/flashing brake), saddlebag spoilers (wired as running/flashing brake) , saddlebag (side) lighted latches and a HogLite mounted under my tourpak (wired as flashing brake).
Load equalizer??? I ain't got no freakin' load equalizer and I don't have any issues either!!! [sm=confused06.gif]
