LED tail light bulb
Old Nov 15, 2007 | 08:37 PM
MHRider's Avatar
MHRider
Default RE: LED tail light bulb
I was wondering if those will work better than what you guys talking about? I know it is very pricey. Just curious.
L.E.D. Replacement Bulbs
// ABOUT APPLICATIONS //
A. L.E.D. Bulbs
These are the best L.E.D. replacement bulbs on the market. Each bulb features 32 mega-bright red or 32 super bright amber L.E.D.s in a completely sealed package. The unique design provides full hemispherical illumination; you won't believe the improvement over an incandescent bulb. It's dimensions are the same as a standard 1157 or 1156 incandescent bulb so it can be used as a direct replacement for those applications.
Note: Because of the very low amperage drawn on these L.E.D.s a load equalizer is required.
B. L.E.D. Wedge Bulbs
An L.E.D. replacement for 12 volt #161 or #168 style push-in bulbs. These are a great way to reduce the load on your charging system if you've added additional lights! Available in red or amber.
C. L.E.D. Bulbs
An inexpensive way to upgrade from incandescent to L.E.D. bulbs. Advantages include low draw, long life, and resistance to vibration. Due to the directional design of these bulbs, it is necessary that the bulb face the lens for proper illumination. Not recommended for '99-E'03 taillights or '86-'07 flat lens turn signals found on Dresser, Road King or Heritage models.
_4800 //$39.99 _ORDER NOW
Red L.E.D. Two Circuit Bulb (ea)
Replaces 1157. Type A
_4801 //$39.99 _ORDER NOW
Red L.E.D. Single Circuit Bulb (ea)
Replaces 1156, Type A
_4802 //$9.99 _ORDER NOW
Red L.E.D. Wedge Bulb (ea)
Type B
_4804 //$39.99 _ORDER NOW
Amber L.E.D. Single Circuit Bulb (ea)
_4805 //$9.99 _ORDER NOW
Amber L.E.D. Wedge Bulb (ea)
Type B
_4815 //$10.99 &n
Old May 13, 2008 | 04:34 AM
luxlighting's Avatar
luxlighting
1st Gear
Dear All ,
We manufacture Led household bulbs ,decoration bulbs ,Auto led bulbs .
Led household bulbs : MR16 : 1W ,3W ,3*1W .GU10 1W ,3W ,3*1W .JDRE27 1W ,3W ,3*1W .E14 1W ,3W,3*1W .PAR30 5*1W ,7*1W .PAR38 12*1W .MR16 with Low power LEDs .GU10 with Low power LEDs .PAR30 With 60LEDs .
Led decoration bulbs : 50mm,60mm,80mm,100mm .120mm .
Auto led bulb ; T10Wedge,T15Wedge,BA9S( 1LED.6LED .Flux .SMD ) .festoon 33mm ,37mm ,42mm ,44mm .
Led tailing lamp .led head lamps .etc .
Our Led package by Famous Led manufacturer .
And quality warranty one year .
Fast delivery .
Best regards
Danny Duan
shenzhen lux lighting technologies co.,ltd
WWW.LUXLEDLIGHT.COM
Add: 904 ,124Building ,Mingle New village ,Longhua ,shenzhen ,china ,
Tel:0086-755-28096562 。0086-755-28096561-888
Fax:0086-755-28096562
E-mail: luxlighting@126.com / danny@luxledlight.com
Msn;gtl-guangzhou-danny@hotmail.com
Skype; sinocolighting
Old May 13, 2008 | 07:38 AM
G$'s Avatar
G$
From: LexVegas, KY...home of fast wimmen & beautiful horses
U don't need no stinkin load equalizer!!!!!
I'm runnin LEDs on my brake AND rear turn signals w/o the dreadedrapid "blink" "blink." Just don't combine with the fronts andu'll be fine.
Old May 13, 2008 | 08:58 AM
Green1340's Avatar
Green1340
With just a brake light you don't need a load equalizer. Only for the turn signals so the flasher operates properly.
Old May 13, 2008 | 10:28 AM
milo8155's Avatar
milo8155
All so true!
milo8155
DaddyKnuck
May 25, 2019 07:46 AM
kbowley
Aug 18, 2018 11:47 AM
Frank the Real Biker
Product Reviews
Sep 6, 2017 08:52 PM
Cozz
Nov 17, 2015 08:07 PM
Dustmaker
Aug 6, 2008 09:38 PM
