Shifter pegs
Old Dec 27, 2005 | 05:18 PM
Mikeeeeeeeeee's Avatar
Mikeeeeeeeeee
"Moderator & Connoisseur of Ice Cream"
Default RE: Shifter pegs
Almost 30 years in the maintenance field.
If it has red loctite on it - apply some heat.
Here is whats happening when you use Loctite. IMagine if you will a Nylock type locking nut. Anyone who has seen one knows that it is the plastic (nylon) insert that is doing the holding.
When you install with loctite you are essentially forming your own locknut as it were.
Red is permanent. Blue is not. Then you get into green loctite (for cylindrical applications) and other types.
If it's red, the heat will melt it and you can easily turn it. If it's blue, a little more force with no heat will ususally get it.
Old Dec 27, 2005 | 06:58 PM
ESS9's Avatar
ESS9
Mike thanks for the INFO, i used vice grips and turned, wasnt to bad.
put the new ones one and the bike looks great.
again thanks all for the help
danny54
Oct 15, 2018 09:40 AM
Siberianhusky
Mar 23, 2009 07:05 AM
Qball
Jun 25, 2007 06:57 AM
Streetrunner
Jan 22, 2007 10:04 AM
Shrug
Oct 9, 2006 05:26 PM
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
