Oil pressure problem???
Old Nov 27, 2007 | 03:35 PM
dgriffith's Avatar
dgriffith
Default Oil pressure problem???
Ever since new, my 06 Ultra has low oil pressure when idling. Real hot 100 deg.plus and the oil light has come on before. 2 dealers say no problem. I run Mobil 1 20/50 now and I've noticed at cooler temps the pressure is up. 40 psi when running at 40 deg. temps. running down the road. I KNOW THAT IS NORMAL. But the bike runs differently, It will run up hill at 1500 with no ping or shake when the oil pressure is above 35 psi. The question is, Is the pressure affecting the cam profile relative to lifters staying pumped up?? I have no lifter noise when colder and a lot when hot. When it's hot outside, it will shake like a wet dog at 2200 when pulling the same hill. I ride the same stretch of roads about 3 times a week winter and summer. Bike has stage 1, V&H Ovals, SERT& Dinoed.
Old Nov 27, 2007 | 04:28 PM
jeepster09's Avatar
jeepster09
Default RE: Oil pressure problem???
Considered normal,AKA exceptable,is 10 lbs. for every 1000 RPM
Old Nov 27, 2007 | 08:13 PM
mllkn6's Avatar
mllkn6
With my 06 Ultra the oil pressure drops when idling to 5 to 10 psi, never noticed it till about 1000 miles ago. Does great when at speed, just during idling, no light or anything just watching gauge. I've never watched it when cold or hot, I just noticed it a while back but be sure now that you have brought it up I will from now on. Thanks for bring this to my attention that someone else is concerned about this. I know there should be a difference in pressure between idle and 2500 RPM's but I don't think it should drop that low at idle. I have synthetic in all holes, but like I said I just started noticing it 1000 mile back. No ping, difference in sound or ride,but vibrates at idle like yours, course I've hadquite a few Harley's and they all vibrated, if it did not vibrate I'd worry.
Old Nov 27, 2007 | 08:56 PM
GlennsGlide's Avatar
GlennsGlide
I never had oil pressure problems as such on my 2006 ultra it just dropped down on hotter days. I recently installed some gear drive cams and when reassembling the bits I paid particular attention to aligning the oil pump and I now have an extra 8 pounds pressure and reduced drop down when hot and idling.Maybe the MoCo doesn't align the pump as good as it could be?.
GlennsGlide
Old Nov 27, 2007 | 09:25 PM
R1Geezrglide's Avatar
R1Geezrglide
My 05 will drop to around 10 psi on hot idle-no light, though. If the idle speed is low, then you may get a flickering light.
Old Nov 28, 2007 | 04:06 AM
dgriffith's Avatar
dgriffith
I have about decided to wait till the warrenty runs out in May, then replace the pump,cams and go to gear drive. I'll be pushing about 30k by then. Thanks for the info. Dan
Old Nov 28, 2007 | 12:25 PM
pop1's Avatar
pop1
When the bike gets hot the oil gets thinner. This is normal. That is why at idle oil pressure has a low reading. (No air) In other words get moving. When the light is on that bike is starving for cool air but that light should not be coming onon a regular basis.
jpalladino820
EVO
Apr 20, 2017 06:43 PM
DC COBRA
Jun 9, 2014 11:04 AM
Reaper22
Apr 16, 2013 03:07 PM
FL-kruzen
Nov 13, 2012 04:50 PM
mtbottles
Jun 20, 2012 11:49 AM
