My fingers are a little large to easily attach the shock pump to the valve behind the saddlebag. This is what I did about it.
I went to the dealer and purchased a Valve Stem Extension PN# 42300009.
I attached it to the existing valve.
[IMG][/IMG]
Then I drilled a 5/16ths hole in the license plate bracket. I put a washer on the threaded end and put it thru the new hole and tightened it up with a shaftnut with the proper threads. (Best luck getting the right nut from a tire store. Hardware and Auto parts stores just gave me dumb looks)
[IMG][/IMG]
Now I have an easy to get to place to check and fill my shocks!
[IMG][/IMG]
Easy to get to and looks nice. I got some new air line from the dealer and am going to re-locate it someplace, just haven't got to it yet. Your solution is simple and looks good. I surprised someone doesn't offer some high dollar "kit" to do that.
The guys that make the EZ lift centerstand (Wheeldock) make one with a gauge, a button to check the pressure, and a valve for adding air. Several types available for different bikes, and very high quality. Comes with air line, nuts and bolts for hooking it all up.
wow. Lots of good stuff in this thread. and what a small world. After reading the entire thing or damn close to it the last post above mine is one I will use and is from a guy in Nebraska just down the road. I am on the way to pick up some stuff ! Ride Safe.
I am working on making my bike show off some of the things that I have from my mnay years in EMS and firefighting. Some have been more costly and would only work for others with the same line of work. One I did would work with any 1" diameter pin/coin/button. I wanted to cover the HD logo on the front caliper. I wanted to cover it in a way that is easy, inexpensive, and removable. So I found a collar pin, removed the pin on the back and attached it to the caliper with RTV. I used a Star of Life pin for my EMS background, but any 1" diameter pin would work.
