"DIY MODS" and TRICKS to SAVE $$$$$$
Old Jul 16, 2015 | 10:29 PM
  #1771
NotAknucklehead's Avatar
NotAknucklehead
Damn... this thread should be converted to a sub forum!
Old Jul 16, 2015 | 11:55 PM
  #1772
Hesh81's Avatar
Hesh81
For all those relocating a License plate and wanting a cheap and clean solution to the need for illuminating the plate at night, I just bought a pair of these and the price could not be beat. I like them because it was such a cost effective and simple solution to the problem on my 06 Road King after making my own relocation bracket. I dont need to replace the lens or tail lamp with a plate window now, and they come in both Silver/Brushed or Black. Granted, shipping (free, fwiw) took about 3 weeks so it must have been sent on the slow boat from.... over there, but for less than $3 I cant complain.
http://www.aliexpress.com/item/1Pair...815192476.html
Old Jul 17, 2015 | 11:33 PM
  #1773
Hesh81's Avatar
Hesh81
Just spent about 30 mins in the garage wiring these up. For an investment of less than $5, this was an good and enjoyable (and relatively easy) mod to do!
For anyone planning to do this, I spliced off the Blue wire that ran to my tail lamp for my + and the Black wire for the ground. I ran the wires back into the fender from inside the tail lamp, and back out one of the turn signal hole grommets to the bolts.
Now I finally have plate lights!
Here is a (poor) pic, but it is VERY bright and clean.
Old Jul 20, 2015 | 08:50 PM
  #1774
fphoenix's Avatar
fphoenix
Default cheap LED brake/turn signal lights
I'm sure it has been done before but here is a cheap alternative LED light if you don't want to spend $90 on custom dynamic lights. i picked this set up at wal mart for around $12. Slight modification of your tail light assembly is required. nothing that a dremmel can't take care of. Start by removing your old bulb. you will see that the new bulb is slightly bigger than the opening. simply make the hole a little bigger and you have new red LED bulbs that are CAN Bus so they will work properly.
Old Jul 21, 2015 | 06:21 PM
  #1775
07FLHRCMarinePatriot's Avatar
So, you specify they're "CAN" types. Is that why they don't need load equalizers?
Old Jul 21, 2015 | 06:56 PM
  #1776
fphoenix's Avatar
fphoenix
that is correct. once you make the hole big enough they are plug and play.
Old Jul 23, 2015 | 12:11 PM
  #1777
albryant's Avatar
albryant
5th Gear
Default 2014 limited Extra Pockets
Easy simple cheap way to add a couple extra pouches. I bought the pair of these pouches for around $5, attached it to the door cover with a couple zip ties. Now I have a place to put a pack of smokes that I can access while riding. I put the other pouch on the back of my back rest for the wife. This one I added snaps to the back rest and bag so that I can take it off if needed. I had the snaps and zip ties lying around, so for $5 and maybe a half hour worth of work, probably the best mod I've done, and saved a boat load of $$$, rather than buying the same concept accessories thru the dealer.
Old Jul 23, 2015 | 08:05 PM
  #1778
Disco Don Anderson's Avatar
Disco Don Anderson
6th Gear
Default Genius, no matter who thought of it.
Just plain genius.
Originally Posted by CREEPSHOW
Here is the most bang for the buck mod I have done yet! Crankcase breather hose. I cannot take credit for it. jag1886give me this tip so hats off to him!
Normal braid line is not cheap. Last crankcase kit I bought was a braided line from head to head with banjo fittings built in was about $65.00.
Old Jul 23, 2015 | 08:57 PM
  #1779
Chief40al's Avatar
Chief40al
Originally Posted by Disco Don Anderson
Just plain genius.
Can't open original
Old Jul 24, 2015 | 06:33 AM
  #1780
beammeup's Avatar
beammeup
Great idea. Where did you buy the pouches especially for $5? I wouldn't have a clue where to start my search.
