"DIY MODS" and TRICKS to SAVE $$$$$$
Old Sep 22, 2016 | 07:56 PM
  #1911
Frank the Real Biker's Avatar
Originally Posted by hardheaded
i'm on the fender skirt idea. did you pinch the tube between the fender trim and fender ?
I just used silicone adhesive to attach it to the inside of the fender skirt, but pinching it between the fender and the skirt is a good idea. That would make it nearly impossible to fall off.
I made the contact area so it covers the entire inside of the skirt. Plenty of "real estate" for the adhesive to hold on to that way. I had one on my 2005 FLHT that was on for 5 years or so.
I did make one mistake on the 2005. I trimmed the flap so it was just a tiny fraction of an inch above the road surface. That worked fine until I hit some gravel or even a single rock. It would scoop it up and it'd rattle around in the fender, making a noise that sounded like a handful of ball bearings and a live duck in a Hamilton Beach blender. I trimmed it up about an inch or two and it has worked great ever since.
Old Sep 22, 2016 | 07:58 PM
  #1912
Originally Posted by checkers
Frank, looking at your linkage pic: Will it align better with the front Heim joint to the inside of the front lever? My RK does.
It's a straight shot from one to the other on my 2015 Ultra Classic. Maybe the perspective of the photo makes it appear crooked, but it's straight as an arrow in real life.
Old Sep 23, 2016 | 07:10 PM
  #1913
checkers's Avatar
checkers
Likely the picture. good to hear she's straight.
Old Sep 24, 2016 | 09:50 AM
  #1914
bundy368's Avatar
bundy368
3rd Gear
Why can't i see some of the pic on this thread
Old Sep 24, 2016 | 03:48 PM
  #1915
Hate Work's Avatar
Hate Work
Try opening up the picture with a different program. Right click and then select something other than what your default is.
Old Oct 4, 2016 | 03:32 PM
  #1916
Rijan's Avatar
Rijan
So wanted to add my GPS but didn't want to drill holes in the fairing. Did the next best thing drilled into my Fairing bags and seems to work alright for the moment
Old Oct 7, 2016 | 02:53 PM
  #1917
Michael Steinrok's Avatar
Michael Steinrok
1st Gear
Originally Posted by NCCopBikeRider
06 Cop Glide
K&N 3909
DIY 2 x 1 Exhaust system.
Cut off and plated the hole on the rear header pipe that went to the LS muffler
Replaced RS muffler with LS muffler
Instant 2 x 1
Good Luck
I had that done on a set of Road House Duallies. It worked like a charm and smoothed out the popping!
Old Oct 16, 2016 | 11:49 AM
  #1918
JOECAKRON's Avatar
JOECAKRON
Here's my Garage Door Opener. I know it's way overdone, but here is mine anyway. I soldered a momentary switch ($3 from Radio Shack) to the 2 contacts and installed it in the empty switch housing on the dash next to the ignition switch. I used 3M Command Strips to attach it to the backside of the dash so I can replace the battery when needed. No hard wire required. I never had to solder before and it took me a few tries to get it right (good thing there are 9 sets of contacts on the remote) LOL.
Old Oct 18, 2016 | 12:54 PM
  #1919
gnalen's Avatar
gnalen
[QUOTE=Rijan;15568151]
So wanted to add my GPS but didn't want to drill holes in the fairing. Did the next best thing drilled into my Fairing bags and seems to work alright for the moment.
Did you use a Ram-B-201U between the mount and the GPS Cradle?
-- Gary
Old Oct 18, 2016 | 08:58 PM
  #1920
Rijan's Avatar
Rijan
Hey Gary I used the Triangle mount(With 2 holes 1 on each point) as that what fit on the GPS cradle for the TOM TOM.
Have not done to much riding with it on there>It did shake a bit not much .Next step if I have to is drill her right through into the fairing but would like to stay away from that. I am going to hard wire it to the front lights once the wires come from China!
