"DIY MODS" and TRICKS to SAVE $$$$$$
Old Jan 7, 2010 | 11:07 AM
  #501
Kingo99's Avatar
Kingo99
From: Chicago & Door Cnty. Wi. Sarasota Fla. In winter
I'm new to this forum,and don,t know how to bring up your images. I am looking for a way to mount a GPS on my new RG. Thanks in advance for your help.
Ed
Old Jan 7, 2010 | 12:33 PM
  #502
bagman1's Avatar
bagman1
Ed
What I did on mine was use the Kuryakin fuel door mount. I like it because it doesnt clutter up the bar or dash area. I think it was like $60
Old Jan 12, 2010 | 07:13 AM
  #503
CT 06 glide's Avatar
CT 06 glide
Default luggage rack on a 06 streetglide
sorry wrong place for this thread.
Old Jan 13, 2010 | 12:46 PM
  #504
1of2's Avatar
1of2
"Moderator"
Default Accesory plug for tour-pak
I have not gone through all the threads here to see if this has been done and how but here is my solution to getting a plug in the tour-pak for charging cell phones etc:
Supplies needed:
HD supplementary power source kit # 91843-97 ($19.99)
Power wire with fuse
Plug for battery tender ($2.99 shipped from eBay)
I have an Ultra with the tour-pak insert. I found there is room (barley) in the back corner in front of the antenna.
Then I cut a hole to mount the power adapter as close to the corner shelf as I could. There is barely enough room for it so make sure it is as close as possible.
I then wired the fused power wire through the grommet that the other wiring goes through.
Run the wire down near the battery and connect the tender plug end to it.
Run the wire down to your battery tender plug and plug it in.
It ended up being a nice clean installation. Now I have power in the tour-pak for under $30.
Old Jan 13, 2010 | 05:39 PM
  #505
Watchfuliz's Avatar
Watchfuliz
Nice job 1of2!! This a really good idea. I think I will do it to mine.
I was wondering if you hooked that up to a switched power soruce? Just a thought so you wouldn't go off and leave something draining the battery when you walk away.
Old Jan 13, 2010 | 11:30 PM
  #506
1of2's Avatar
1of2
"Moderator"
I intentionally hooked it direct so I can charge my phone or whatever even when I'm not riding.
Old Jan 14, 2010 | 08:47 AM
  #507
cwoof's Avatar
cwoof
Do you find that the tour pack liner is sturdy enough for the pushing and pulling your plugs in and out of the socket, or did you have to reinforce the back?
Old Jan 14, 2010 | 09:00 AM
  #508
1of2's Avatar
1of2
"Moderator"
No worries there. It is plenty strong enough. Works great!
Old Jan 14, 2010 | 01:44 PM
  #509
Sancho's Avatar
Sancho
All painting done with rattle can bc/cc then hand rubbed out.
Gold pinstriping
XM radio antenna mount (upside down auto door lock)
axle covers (DAWGs idea) PVC pipe covers
Painted rear strut and docking hardware
Painted Logo
Old Jan 14, 2010 | 01:48 PM
  #510
Sancho's Avatar
Sancho
Painted horn cover rattle can
Led lights autozone
Painted mirror inset
Deep fryer thermometer to check oil temp. $3.50 (it works)
