"DIY MODS" and TRICKS to SAVE $$$$$$
Old Sep 24, 2010 | 10:01 AM
  #661
Wynndaddy's Avatar
Wynndaddy
Alot of good ideas .
Old Sep 24, 2010 | 01:45 PM
  #662
randytro's Avatar
randytro
Default Wind no more
Old Sep 24, 2010 | 02:07 PM
  #663
pretz's Avatar
pretz
From this thread; I took my garage door opener and wired it to a momentary switch. I secured the opener inside the Batwing, drilled a hole through one of the blank switch covers and inserted the switch. Works like a champ and easy as hell to do.
Thanks for the thread
Old Sep 24, 2010 | 10:27 PM
  #664
MSgt Rose's Avatar
MSgt Rose
Lets see; I completed the garage door opener mod with a with a momentary switch ($3.69 for switch, already had an extra garage door remote). I have completed the foot board 1 inch extension mod with a few old bushings found around the garage and some grade 8 bolts bought from a local hardware store (Less than $7.00 for all the grade 8 bolts). I completed the driving light mod, so they work with your high beams (Free - had the connectors, heat shrink and solder in my tool box). I completed the base sticker mod (this was the most expensive mod by far..... cost me a big ole farkin dent in my front fender and a few tears). I need help...... can a paint-less dent remover guy pull a mild crease from something like a fender and also from my brothers in arms, I need some good ideas on where and how to mount a base sticker without causing a big ole farkin dent.
Old Sep 25, 2010 | 10:44 PM
  #665
Ron "Gunner" Retzlaff's Avatar
Top,
1.) What type of bushings did you use to extend the floorboards out? I have thought about this same thing, but wasn't sure what to use for bushings. 2.) I run security for a Navy base and we don't care where you place your base sticker as long as it is "attached" to your bike. I took a piece of aluminum flat stock from the public works metal scrap bin and cut it a little bigger than what my decal size was. I bent it about 15 degrees so that it would not sit flush against the brake caliper. I drilled holes the same size as my brake caliper bolts, I removed 1 bolt and replaced the bolt without tightening it down, I removed the other bolt and replaced the bolt tightening each to spec. Works great and doesn't really show until I pull up at the gate and the sentry either sees it or I point to it. Total cost zero dollars.
Old Sep 26, 2010 | 01:52 AM
  #666
MSgt Rose's Avatar
MSgt Rose
Not really sure where the bushings came from, had them laying around my garage probably for years, luckily they fit perfect with a 3/4" outside diameter and a 3/8" inside diameter and a 1/2" width, so I had to use 2 for each bolt. I forgot to mention that also had to use a piece of steel pipe for the rear of the left hand foot-board. The pipe I used was was 1/2" outer diameter and 1/4" inside diameter. I cut it down to 1" sections and worked great.
Thanks for the idea on using the brake caliper for mounting your base sticker. I will look into modifying a bracket and bolting my current plate to it.
Old Sep 26, 2010 | 08:44 AM
  #667
katobird's Avatar
katobird
Default Homemade footrest
Stirrups / footpegs whatever
I found I used my front edge of floorboard as support, after a while heel started hurting..
With my feet on the highway pegs after a while I found myself "pressing hard" with my feet.
I made these and it took all the weight off my foot. work Great
The bitch was polishing the stainless
Attached Thumbnails  "DIY MODS" and TRICKS to SAVE $$$$$$-footpeg.jpg    "DIY MODS" and TRICKS to SAVE $$$$$$-footpeg-2-.jpg
Old Sep 26, 2010 | 05:34 PM
  #668
This is what my plate looks like, it is very simple and took no time to make. Just remember to bend your plate so that it doesn't want to sit flush on top of the caliper, it needs to have air moving around it to expel the heat & dust from the pads.
Old Sep 26, 2010 | 08:51 PM
  #669
MSgt Rose's Avatar
MSgt Rose
Thanks, the pic helps a lot
Old Oct 18, 2010 | 02:02 PM
  #670
Duc's Avatar
Duc
Not sure if it has been mentioned on a previous page but I cut up my stock airbox and installed a K&N.
Wanted an A/C but couldn't see what the money was all about when my mod looks and breaths the same for the price of a filter.
