OK with header only?
Old Dec 10, 2007 | 07:03 PM
WORKD4IT's Avatar
WORKD4IT
Default OK with header only?
I started installing Klock Werks double back header today. I was told I wouldn't have to do a tuner with header only. Only when you change the intake. Is that true? I have the big sucker in the box but I thought I would get the SERT for Christmas and install it then. Can I just do a ecm reflash? Thanks everyone!!
Old Dec 10, 2007 | 07:12 PM
NCCopBikeRider's Avatar
NCCopBikeRider
Default RE: OK with header only?
Might be a great learning tool to use the search function at the bottom of the page, read all of the posts, then make an informed decision
Good Luck
Old Dec 10, 2007 | 07:28 PM
WORKD4IT's Avatar
WORKD4IT
I always post first and then do a search. Put my question out there to see who bites while I read old posts but thanks for the great info.
Old Dec 10, 2007 | 07:38 PM
SoCal_Pappy's Avatar
SoCal_Pappy
You'll Need To.... You can get away with slip-on mufflers (in most cases) - but going to change the headers you need to get yourself a Fuel Management System (just doing a download\flash will still be running within EPA requirements (LEAN) - Might as well finish the Stage 1 if your going that far (Mufflers & Air Kit) & don't ride it to much (if any) till it's done...
Old Dec 10, 2007 | 07:42 PM
lkr0's Avatar
lkr0
SoCal Pappy is correct --- don't worry about the search it's at least a 100 people here waiting to provide answers
ORIGINAL: SoCal_Pappy
Old Dec 10, 2007 | 08:07 PM
WORKD4IT's Avatar
WORKD4IT
Its gonna be hard to let her sit down there till after Christmas but I don't want to mess anything up. I knew I should have just left that box under the tree
Old Dec 10, 2007 | 08:14 PM
Plunk's Avatar
Plunk
If you can avoid it, do NOT buy a SERT. Go for a Power Commander instead. They are easier to tune, they work better and save tons of dyno time. Did I mention cheaper?
Old Dec 10, 2007 | 08:42 PM
sewerat's Avatar
sewerat
i'd have to agree with about?????? 1 of those answers, yes for the laymen they are easier to use, they make them idiot proof but to say they are better is by far spoken by somebody who does not have the experience with them. PC still need a pile of dyno to make them run right. Canned maps are only as good as the last guy made them for his bike not for yours.
bdavis
Jun 25, 2012 10:37 PM
FLHRC 08
Aug 12, 2008 07:11 PM
JonnyD
Mar 3, 2008 10:57 AM
UltraClassic_2007
Sep 3, 2007 08:24 AM
DoubLeL
Aug 14, 2007 11:47 PM
