Primary Chain Auto Tensioner
Old Dec 15, 2007 | 02:07 PM
mike_oh's Avatar
mike_oh
Default Primary Chain Auto Tensioner
Does anyone have experience witht the automatic chain tensioner that is offered for the primary chain? I know this is standard equipment on 2006 Touring models. H-D sells this as an option for older bikes.
Old Dec 15, 2007 | 02:08 PM
Jim Dawson's Avatar
Jim Dawson
Default RE: Primary Chain Auto Tensioner
When I had my '03 Dyna Low Rider I installed the tensioner and had no problems.
Old Dec 15, 2007 | 02:11 PM
nedster's Avatar
nedster
had it on my 04 road glide, smooth as silk. no problemo
Old Dec 15, 2007 | 02:16 PM
Moe55's Avatar
Moe55
Installed on 05 Ultra only have 1,000 miles on it. No noise never know it was there. One less thing to do on a service.
Old Dec 15, 2007 | 03:29 PM
Retired_Ted's Avatar
Retired_Ted
Here's the one I installed on my RK shortly after I purchased it. Easy install and it worked as advertised.
Click >>>>HERE<<<<
Old Dec 15, 2007 | 03:46 PM
quad50's Avatar
quad50
I had one installed in my 06 Heritage new. I had 21,500 on it when I sold it. I just did an oil change on it for the guy I sold it to. It"s got 30,000 + on it now. Checked the tensioner, and it looked great.
Old Dec 15, 2007 | 04:25 PM
Egldr05's Avatar
Egldr05
I didn't care for it myself, thought it kept the chain a bit on the tight side. I went back to stock, make me an offer if interested.
Rick
Old Dec 15, 2007 | 04:40 PM
jeepster09's Avatar
jeepster09
I used the Harley one, over 8000 miles without a problem.
Old Dec 15, 2007 | 04:49 PM
Sleeps In Trees's Avatar
Sleeps In Trees
There were 3 makes of these available when I researched it last yr; HD, Hayden M6, & the HB-125. I'm sure they're all good, but I chose the HB-125 due to having uncovered less probs reported w/it. Very happy w/my choice.
http://www.shopsohotbikes.com/shop/p...ductId=3963421
VicW.
Old Dec 15, 2007 | 05:00 PM
iclick's Avatar
iclick
I've had two of these, one I installed in my '96 RK and the second standard in my '07 SG. My understanding of the device's machanics is that it can't over-tighten unless it is adjusted too tight at install, so if you buy it follow the instructions carefully. Once adjusted properly it should maintain a good adjustment indefinitely. Make sure you have an impact driver with a large (#1 or #2, IIRC) Phillips bit, as that will be required to remove the old tensioner--or at least it was on my '96. Mine was difficult to remove. Why they would use a Phillips-head bolt in such a place that is Loctited into the inner primary is beyond me.
OTOH, I don't think I would advise retrofitting this or any other auto-adjust tensioner. The reason is that the chain should require few adjustments after about 10k of break-in miles, or at least that's been my experience. You could check it once every 10k and adjust if necessary, as adjustments aren't too involved, and this way you save your HD ($100).
