Hard Bag Conversion for RKC
Old Dec 24, 2007 | 06:53 PM
masterblaster's Avatar
masterblaster
Default Hard Bag Conversion for RKC
Just mounting hard bags on the RKC, are the mounts the same for the hard bags as they are for the leather bags?
Old Dec 24, 2007 | 06:55 PM
fishafly's Avatar
fishafly
Default RE: Hard Bag Conversion for RKC
Yep... I added 'em to my custom no problemo...
Old Dec 24, 2007 | 07:07 PM
framer's Avatar
framer
Man, that front end is way cool !!! That sorta mod is my next one. I really like your choice of wheels, can you give me some details on what the parts and cost would run?
Heres what I'm working with...
http://i263.photobucket.com/albums/i...ng6142/012.jpg
Old Dec 24, 2007 | 07:49 PM
YodaddyKeith's Avatar
YodaddyKeith
I'm doing the same thing, just waiting for new fairing so I can get all painted at once......
All you do is get yerself a 7/16" wrench and then loosen the bolts that hold the latchpin brackets to bike enuff that you can rotate and move them around. Next fit the hard bag on the bottom rail and slide the bag into the position you like forward/aft.....then insert latch pins into latch brackets and tighten bracket bolts(you will need to rotate and adjust brackets to new position as you do this).....Look down from above to make certain both bag are equal distance fore/aft before you tighten opposite side.
Old Dec 24, 2007 | 08:20 PM
masterblaster
Thanks Yodadykeith, I did that exact procedure, my concern is that the forward and and aft mount are spaced differently from the bike, the front mount seems closer the bikethan the rear mount. Is that normal, they seem to fit horizontally but not laterally. i will post a picture tomorrow.
Old Dec 24, 2007 | 08:35 PM
YodaddyKeith
Yes, it is normal.....Look closely from above and you will see why the front bracket doesn't extend away from the bike as much as the rear....The rears must be longer to compensate for the narrower area they bolt to......
If in doubt, just ask dealer parts guy if part numbers are same for mount brackets......The worst that can happen is you would buy a pair of either front or rear brackets to make bags install parallel to fender.......Mine look fine, but who knows how yours look depending on year of bikes/bags.
Old Dec 24, 2007 | 09:25 PM
harris48cars's Avatar
harris48cars
I have a nice set of hard bags complete, right down to the keys. Way to nice to repaint. Luxury Rich Red. $700
Gary
Old Dec 24, 2007 | 10:04 PM
bulldogmoe7's Avatar
bulldogmoe7
hey masterblaster post some pics when you are done. thought about doing that myself.
Old Dec 25, 2007 | 01:27 AM
PapaTravis's Avatar
PapaTravis
ORIGINAL: masterblaster
You can put a washer (spacer) on the bolts (between the bracket and the fender rails)for the front mount, to move it out a bit. I actually had to do this to my rk custom bags, so the bolt would stop eating up the lid of the bags...
Old Dec 25, 2007 | 06:48 AM
Pastor John's Avatar
Pastor John
I replaced the leather bags on my Road King Classic with hard bags to get the additional weather protection and security. They went on easily with just a minor readjustment of the mounting tabs. I hung around eBay for about a month before a set in my color finally came up for sale.
