adding gauges in the fairing
Old Dec 27, 2007 | 09:26 AM
patsac's Avatar
patsac
Default adding gauges in the fairing
going to add the oil pressure and air temp gauges to my 07 e-glide standard.....any hints, advise, tricks..that might help me out?
Old Dec 27, 2007 | 09:34 AM
BOARGAURD's Avatar
BOARGAURD
Default RE: adding gauges in the fairing
Simple install but the air temp is useless. Need to get a oil temp gauge instead.
Old Dec 27, 2007 | 10:04 AM
Harleypingman's Avatar
Harleypingman
+1 on using an oil temp gauge instead of the air temp gauge.
The plugs that are currently in the holes for the gauges can be pushed out once the fairing is removed, or can be removed from the front with careful use of a 90 degree pick tool.
Old Dec 27, 2007 | 10:12 AM
pop1's Avatar
pop1
If you just want gaugesthere aresome more accurate ones. Autometer or the dakota digitals look bada$$
Old Dec 28, 2007 | 02:12 PM
patsac's Avatar
patsac
yup i know about the oil temp gauge being better that the air temp gauge...this is a xmas gift and it came as a kit from the dealer....was just lookin for some advise on the installation
Old Dec 28, 2007 | 03:48 PM
TN Houndog's Avatar
TN Houndog
I put an oil pressure guage and a clock in mine. My 06 model already had the wiring and oil sender unit needed for installation and it was basically "plug and play". You probably won't need the sending unit or the wiring in the kit. You can save some $$$ by just buying the guages separately if your scoot is already prewired. I'll second ditching the air temp guage and replacing it with an oil temp guage or a clock! It took me 30 minutes or so start to finish for the installation of both guages, and getting the outer fairing off was the hardest part of it all.
Old Jan 11, 2012 | 04:03 PM
kdodd's Avatar
kdodd
I have a 2003 Electra glide, I also bought the air and oil pressure gauge kit, it came with all the new wiring and a new sending unit, someone told me I did not need to replace the sending unit that is there now. Pretty much plug in and go. I'm trying to do more of my maintenance, so bare with me on these questions.
Rich67
May 27, 2017 08:12 AM
pavementpilot
Oil Archive (no new posts)
Dec 24, 2008 10:58 AM
BadX
Jun 9, 2007 01:51 AM
Blacklion213
May 8, 2007 06:21 PM
geargrinder
Jan 21, 2007 10:12 PM
