Tires
Old Jan 5, 2006 | 08:31 PM
03RKC's Avatar
03RKC
Default Tires
I'm getting ready to change the stock tires on my 03 flhrci. I'm not sure if I want to put Dunlops back on. Would like any feedback on Avon or Metzlers. Thank-ya kindly.
Old Jan 5, 2006 | 08:43 PM
MACK's Avatar
MACK
Default RE: Tires
Metzler is a great tire. Avon is better I think for choppers and crotch rockets. I use the Dunlops because they are a good tire and any Harley dealer will always have one in stock if you need it on the road. Most dealers do not stock metzlers or Avons.
Old Jan 5, 2006 | 09:33 PM
CHEYENNE's Avatar
CHEYENNE
Default RE: Tires
Metzler is the way to go. If I didn't have so few miles on my bike I would be chaning out these sh*tty Dunlops in a heartbeat. I run Metzlers on my sportbikes and they are a great tire. Also Metzler will be a little softer compound so you will get a few less miles then a Dunlop depending on your riding habits.
Avon i have no clue about.
Old Jan 5, 2006 | 11:15 PM
Lpye's Avatar
Lpye
Default RE: Tires
I have used boh. The AVON had issues with cracking between the threads. Avon eventually made the tires good and said it was a design / weight issue. The reccomended increasing the air pressure from that listed on the side wall. I got the new tires, but never mounted them. Traded them with a local wrench. The Metzlers were ok, I just didn't seem to get the mileage out of them. I went back to Dunlop.
Old Jan 6, 2006 | 03:51 AM
Inforit's Avatar
Inforit
Default RE: Tires
Talked to local mechanic about which tires to get cause I am need for the rear once and he said you better off with Dunlops. From his experience and customer complaints about the Metzler tires wearing out too fast and uneven at times. So they end up coming back and changing them for Dunlops. So I will continue using Dunlops.
Old Jan 6, 2006 | 11:17 AM
spartns's Avatar
spartns
Default RE: Tires
I've never tried Avons but, I've used both Metzlers and Dunlops. As said above, the Metzlers are a little softer and you get a little better grip. Having said that, the Metzlers lasted half as long and cost more. I just put another set of Dunlops on.
Chris
Old Jan 6, 2006 | 11:53 AM
SiCkEl_RiDeR's Avatar
SiCkEl_RiDeR
Default RE: Tires
I won't presume too understand why you came down too those 2 tire brands. But I'll challenge you to a test. Go to any cycle shop and locate there dead tires spot. Look at any brand you wish and then grab a DUNLOP Elite and put them side-by-side and focus directly at the SIDE-WALLS. You'll will probably see that the thickness of a DUNLOP to any other brand on the sidewall is approx. double the thickness.
I won't go into the details of why that is important.. suffice it to say.. the heavier the bike the better it is to have thickness vs. performance.
Hope that helps you decide.
-SR[sm=ttiwwp.gif]
[IMG]local://upfiles/6522/7D03F89E61324C4B8EB9A7BCAD13F597.jpg[/IMG]
Old Jan 6, 2006 | 12:11 PM
FLHTPjeff's Avatar
FLHTPjeff
Default RE: Tires
Anybody have any experience with the Michelin Commander? I'm not a big fan of the Dunlops that are on my bike now. They seem to wear fine, but traction seems worse with these tires than any of the others that I've owned. Particularly in the wet, they do not inspire confidence at all. I'd rather replace more often and have better traction.
Old Jan 6, 2006 | 02:21 PM
turbo54's Avatar
turbo54
Default RE: Tires
I have avons 'they have alot of wear bar left but there seperating like the rubber flaking off not good I was told avon tires are to soft for a heavy bike. I have avons on my 1400 Intruder there good on a lighter bike.My friend had the same trouble with his avons.Im going to change them out with dunlaps
[IMG]local://upfiles/3159/4A8989BC32FC4807815AD36F8B8EE7E6.jpg[/IMG]
Old Jan 6, 2006 | 02:27 PM
turbo54's Avatar
turbo54
Default RE: Tires
YESSSSSSSSSS road zeplin air air seat
[IMG]local://upfiles/3159/A8235406AE5447FB9A20D05F6342688A.jpg[/IMG]
Ozark Azz
Wheels/Tires
Jun 15, 2012 07:00 PM
rdam
Mar 8, 2011 09:43 AM
OLD 96
Oct 2, 2010 09:13 AM
brutalbrad
Jun 29, 2010 06:46 PM
SportyPig
Oct 19, 2007 04:04 PM
